If anyone can find the generator for this that would be great.
This was created by Vi Hart’s dad.
Hmm you might be able to do this with some deformation tools in inkscape/etc ?
Maybe lattice deformation?
Ah no envelope deformation would be what I’d go for:
http://tavmjong.free.fr/INKSCAPE/MANUAL/html/Paths-LivePathEffects-EnvelopeDeformation.html
How about something like this?
Edit: made this one from the same puzzle but broke it app art first then tweaked the dimensions of the outer box to kinda match your shape above. then made the inner puzzle section smaller and inside that object and used the envelope extension.
I assume you probably already found his site but just in case you didn’t run across it here it is. lots of cool things in there hidden around.
http://www.georgehart.com/
Funny enough I watched his daughters youtube videos before I had a laser. I sent them to my daughter to encourage her interest in mathematics.
Engrave pattern/cut
I have been playing with a puzzle design that all the pieces are exactly the same. Tossing in a twist so they are almost exactly the same and then a pattern similar to yours would be most interesting.
Sounds cool, you will have to send me a pic when you make it.
Maybe this will help.
If that’s too easy you can add to the insanity by using clear acrylic. (Seen on Etsy)
For the Illustrator peeps using the envelope distorts will do the bendy-wendy trick.
hehe i made one like that for a fiend the other day, will see if she is still a friend after trying to put it together lol
