Anyone seen this insane thing yet? Gizmodo just showed it to me.
I just saw it on gizmodo, too! As I watched it, I just kept thinking âSo how am I going to make this with the Glowforge?â
I hate when people use terms completely wrong
Not a fractal. At all.
And also, it would be pretty trivial to make with the Glowforge.
Just create a little 3 pointed star thing, and then place them end-to-end, stacking to fill any size of grid you want. Choose a few random sets to trim around (and in some cases through) and you are set.
The build isnât the problem , as you said. Itâs all about design. We live in an age where itâs no longer about what you can or cannot create, its about thinking up what you want, and how much your willing to spend.
Yea, thatâs pretty much what I came up with. I was mostly trying to figure out a way to not have to put in all those fillets manually. But I donât really have to use rounded ends.
Theyâre pretty cool. I just built one using a hilbert curve I drew up many moons ago.
I rejigged it slightly and separated it into puzzle pieces.
You can have the file to cut your own too
svg file which may not display correctly in browser window
It is a space filling curve, and in the limit of infinite iterations, is most definitely fractal.
Madelbrot discusses the fractal nature of space filling curves in his books.
Guessing you can find similar patterns online to trace/recreate/tweak to make the pieces, so aside from the design Iâm betting something like this would be pretty simple to make: take 2 boards, cut the pieces out of one & adhere the remaining frame to the second board as a base & youâre done. Make it even more confusing by etching another pattern over the top before you cut so when the pieces are out you still canât tell where anything is supposed to go.
You mean etch a pattern on the pieces you cut to eventually be the puzzle?
That would make it easier, since then you have lines to match up between pieces, giving another indication of which ones go where.
Leaving it completely plain makes the puzzle considerably more devious. Which is why some people solve normal puzzles with the image face down, so they do it by shape alone.
@ccox At first I agreed with @jacobturner about the shape not being fractal, but now I see youâre right. Even the most âfractal lookingâ images we see, like the Mandelbrot set, are really just approximations of fractals, limited by the pixel resolution of the imaging device.
Well, I havenât run into the space filling curves thing before.
For me, the informal fractal definition is self-similarity upon zoom, and infinite zoom. The formal definition is that scaling the perimeter results in a non-integer power in the scaling factor for the area.
But⌠researching a bit, it would seem there is no agreed upon full definition. So Iâm just being an ass.
Trying the hilbert puzzle right now in pizza box cardboard. Going to see how well that holds up.
Fractals are indeed a tricky concept. At the risk of moving this thread too far off topic, here is a mind-bending thought. I made this cover story image for Science News back in '87: http://designbyalgorithm.com/wp-content/uploads/2014/11/Science-News-cover.jpg
The four colors represent four âbasins of attraction.â Get thisâALL FOUR colors meet at EVERY POINT on the boundary between the four basins of attraction! Wrap you head around that one!
The Newton method to find roots?
Yep! Roots of z^4-1=0, to be specific.
My second design is based on the Gosper curve and is much more challenging. Turns out having friends round for Christmas day allowed me to do some awesome laser cutting.
That is fantastic! Would you be willing to share that file too? Iâd love to cut one out!
Never got back to posting on here. I have cut the square file which @m_raynsford uploaded a few times now. Always on a pizza box.
Having an image on the thing you cut before making the puzzle reduces the complexity to an amazing extent. Without that, my kids would have killed me for suggesting they try to put the puzzle together.
And having a solid backing is VERY highly recommended. These guys are a pain to move around without it.
I did a third puzzle as well, never got round to putting them in my web shop. Too many things to make, not enough time to make money ![]()
I bundled all 3 puzzles into 1 svg file, credit where credit is due please and all that
svg file
These are fantastic and already a huge hit around the office. Thanks for sharing!
How did you go about making the design? I tried doing something similar with the Dragonâs Curve fractal, but I wasnât able to create a sensible puzzle easily. It didnât add up into a set of removable shapes all that wellâŚ
I started with the curve, I closed off one entrance and then found a repeating section and then closed it off. I âcutâ it out as a shape and moved it over the next repeating section. I closed the next section at a slightly different point (because I like to be awkward) rinse and repeat. You always end up with a few straggly parts and I had 3 iterations of the dragon curve to get to something useable.
