I’m realizing that I’ll need to seal all my wood (non proograde) pieces to prevent moisture expansion and warping. What’s your favorite product and method for doing this?
(I’m looking for a natural looking solution, but wanna hear all your favorite methods and products)
I tend to use miniwax its the cheap stuff at the hardware store. I used the waterbase (quick drying) and the other. The quick drying did a good job on a few tables I made for inside.
For small projects, I find it hard to beat a satin lacquer. You can apply a few coats in a 30 min period and it doesn’t have much sheen, so it looks more natural. That will help keep moisture out. Also, shellac is a good option for painting multiple coats and having them dry quickly.
I’ve used a bit of everything but I really like the look of paste wax. It gives the wood a hand-rubbed appearance. I also use danish oil quite often if I want something that penetrates.
Not really that shiny, at least in my experience. It’s quite a quick process too. It’s not going to be as hard and protective as a polyurethane but I’ve used it for coffee tables and other furniture with very good long-term results.
This is a repeat of many other threads on the forum, search for it, it’s out there… but a number of replies here are much exactly what was discussed there too.
Use thin CA – I use a “water thin” kind from Starbond; EM-02. Bubbles are nearly impossible with glue this thin.
Naturally, the down side is that the damn stuff wants to go everywhere, so I do this on a silicone mat and use polyethylene gloves.
But really, CA polish looks just great when it’s done, and the micromesh pads work quickly. I picked up the trick from pen turners, who apparently have been using CA this way for a number of years.
