Wood Inlay Skull Pins
I made some little inlaid hardwood skull pins for friends and family to help celebrate the “spooky season.” I always have ideas for this time of year and, rarely get to them. So, I am pretty stoked to have made these.
These are white oak, walnut and, padauk. After gluing and sanding, I applied three coats of wipe-on poly, sanding with 1000 grit between coats and after the last one. Pin backs attached with construction adhesive.
Two-minute making-of short:
Blog post with a couple more photos:
Thank you for sharing this project. I am glad you were able to get to this project which turned out amazing. I am sure your friends and family will love them.
These turned out awesome!
They look great! Great inlays!
Love these! And you made them early enough in Spooky Season that they can get a lot of wear!
Fun design!
They look great
I love inlay. I haven’t really done any, but I love the look.
You make it look easy. Very nice design and a fun looking project.
Very nice!
Excellent job on the inlays. Getting inlays right always tests my patience, which isn’t great to begin with.
Adorable! Don’tcha love the feeling when the inlay pops into position :slight_smile:
I’m blown away by the tiny details. Those little pins are a whole lot of work! And now I’m wondering what construction adhesive is—never heard of it!
@evermorian that is a pretty snug press fit for such detailed pieces. Congratulations!
Probably most commonly known by the brand name Liquid Nails.
According to Make’s adhesives chart, it is a good choice for bonding metal to wood. I have previously used either wood glue or e6000 and, those have seemed okay.
Those look really fun. no idea what would make you think about making them :slight_smile:
Excellent work! What was the thickness of the material, and what were your cut settings?
All of the stock I used was nominally 1/8"/3mm, though there was some variability in thickness.
Settings also vary by type of wood, often even between specific pieces of wood. It is really better to test each specific piece of wood to get optimized settings, especially if you have features like the point of the spirals that will burn off easily.
I use this New Material Test Cut Method approach.
I ended up using the same settings for the maple and walnut. The padauk required more power to cut through than the maple or walnut.
Glowforge has asked us not to share settings anywhere besides the Beyond the Manual section. So, specific settings are there.
I’m just seeing this now for the first time, this is absolutely brilliant, I love the video. Thank you for sharing.
