I’m looking for a new furniture unit to hold the Glowforge. I know that the published dimensions are 38" wide x 20.75" deep. But how much “cheat” is there where the GF actually connects with the tabletop surface? Does it have feet which are inset by a little bit?
I’ve checked out the previous posts here; I’m hoping for some definitive and updated info.
You’re saying that technically I only need a footprint space of 13" by 34"? That’s great news! I was having problems finding something that had a table surface 21 inches deep.
Just to let you know. Need someplace other than the top of the Glowforge to lay your tablet or laptop. You will want it at the machine. And I now have scraps laying all over the top of the Glowforge, edge of the table and on the floor. Flat surfaces are at a premium. Even the top of the washer dryer is starting to collect drawings, Proofgrade, calipers, masking material, etc.
I have one of those Husky cabinets in my studio. Currently, it holds my dye sublimation printer and heat press. I’m considering using it for the Glowforge. The wheels will make it easy to pivot out so I can use the pass-through slot on my Glowforge Pro. But I am concerned that it is a little too tall for comfortable use.
I suspected that might be an emergent issue, and was considering another pull-out surface for lay-out, building and general accumulation of cosmic debris.
You just solidified my decision.
Ah. That’s clearer. I think @dan had a post somewhen about how high (in a discussion about outfeed table height IIRC). The pre-releasers might know as well - if the plastic is the same except that the slot isn’t cut through on the basic but the molding is there. @takitus or @karaelena would be good ones to sniff that out.
Should be pretty easy to get pretty close - the tray height should be the same height as the base of the slot so that stuff will slide in on the tray and not wobble or require spacers. Anyone with a basic unit could measure that too.
My infeed/outfeed table will be height adjustable so I can make up for slight variations in the floor as I move the table around. I’ll have it against the wall unless I’m doing something with the pass-thru and then I’ll just spin it around or move it into the center of the floor. That’s also one reason I got the filter - won’t need to worry about the hose on the back.
That’s going to be a really tough question to answer, because the machine is curved on the bottom, and sits on runners. Do you want the measurement from the bottom of the front face, or from the table surface? Or from the inside of the machine?
The tray that sits inside a recessed area is about 1.5" tall, and any slot would have to feed the material in at that level, but that is not the distance to the table top, because of the runners. Which measurement do you want? (Or better yet, what do you need the measurement for?)
