Due to recent events we are all a little more concerned with what we are touching. This allows you to open pull doors with the hook, latches with the ring, and manipulate deadbolts or bathroom locks with the slot without touching something a lot of others are touching. SVG included. Made with PG 1/4" Acrylic, designed with Fusion360 with Origin Sketch to SVG plugin. I will be testing with other materials.
Hand sanitizer for everything! It has been tested and used by me for a couple of years now. even earrings soaked in it till the masking floated away, two years ago and still shiny.
You could embrace the crazing by a lit score of pseudo-crazing lines so with the real crazing you’d get a nice overall random line effect. Maybe a lichtenstein pattern?
Thanks for sharing the file! I’ll definitely will print one out!
p.s. if you edit your message - see where the svg file link has size numbers… perhaps something like 19x11? add a zero to those, i.e. 190x110. That way the svg image will be more visible.
Just printed one out and wondering if the size is correct. This could be one of those AI vs Inkscape things. The tool lengthwise for me is 5.75". Can someone please pull the file in Illustrator and tell me how long it should be? Thanks!
