So I have a B&W high-res PNG I want to use for an engrave, and then to have it cut out. If I take the image and put it into Inkscape and draw a red circle around it (it’s a circular graphic) then export it as an SVG, the Glowforge will read it correctly and separate the engrave from the cut. But if I make the image in Photoshop with the red line and export it as an SVG, even though the GF recognizes it as a separate layer, it won’t switch from engrave to cut for the red line because “bitmaps can only be engraved.” Is there a way to make a red cutline with Photoshop and have the GF read it correctly? Thank you.
Correct. PS is not producing vector output. Just because the file type is SVG, does not mean it’s vector.
Start by looking here: The Matrix - Tips and Tricks
You’ll find two good articles about creating vectors in Photoshop:
I’ve moved this to an appropriate forum. P&S is for technical support issues (although they will likely check in here now, as a support ticket was created when this thread was opened in that forum).
Thanks for all of the information! I will go ahead and use Illustrator since I do have access to that at work.
Inkscape is just as capable for GF design work, and is free, if you’d prefer to work on designs at home.
