In that case, it might be something in the file. If you want to send me a copy in a PM, I can take a look at it to see if there is anything amiss in it. (Or you can post it here if it is not proprietary.)
To post the file…zip it first…then drag and drop the zipped file onto a new line in your reply.
Thanks for your help Jules. I am waiting to hear from a GF support person. I need to attack all the other things on my list. I am also working with my brother who has been using this machine for years. He is also stumped.
Hi Marc, I am still having all the issues. I went through complete diagnostics with someone on chat. Took close to 45 min. He said he would have to take it to a higher technician.
(10:55:50 PM) Glowforge: Hello - do you have any questions for me?
(10:55:59 PM) Julie Ogle: I have been posting on the community support forum for some problems on my new basic. I actually have a laundry list and would like some direct support.
(10:56:35 PM) Julie Ogle: 1. Brings up old scans while working on project.
(10:56:37 PM) Julie Ogle: 2.
(10:56:53 PM) Julie Ogle: 2. More passes than requested. Up to 4.
(10:57:15 PM) Julie Ogle: 3. Brings up old projects as I am sitting there.
(10:57:30 PM) Julie Ogle: 4. Different intensities in cutting during the same project.
(10:57:39 PM) Julie Ogle: Same cut I mean.
(11:00:09 PM) *** Dakota G joined the chat ***
(11:00:43 PM) Dakota G: Hi Julie, I’m so sorry you ran into trouble! Give me a few minutes to investigate this.
(11:01:26 PM) Julie Ogle: It is only a week old. Not even a week.
(11:02:51 PM) Dakota G: Can you let me know the date and times of some of the prints that have had issues?
(11:03:03 PM) Julie Ogle: I open and closed the lid and it gave me another image.
(11:03:20 PM) Julie Ogle: 2 min ago and over the past 3 days.
(11:04:54 PM) Dakota G: Thank you for confirming. I’m investigating this now.
(11:05:22 PM) Julie Ogle: I have done a recalb. and a Gift of good measure.
(11:10:44 PM) Julie Ogle: I have had fewer problems on my old one that is currently being sent in for service.
(11:11:01 PM) Dakota G: Thank you for waiting. Regarding the issues with old scans and projects being brought up, if possible, can you take screenshots showing what you are experiencing with that?
(11:12:10 PM) Dakota G: Also, I noticed your forum post about the settings. Since the outage has been resolved, did your settings come back?
(11:13:21 PM) Julie Ogle: Yes the setting are back. I turned the machine off so I can not send you a pic. Although it was only of a piece of wood I used days ago. I am more concerned about the passes and inconsistent cutting during a single cut. I posted pics of this.
(11:15:29 PM) Dakota G: Thank you for confirming. Regarding the passes, I see in your prints that they were set to do 2 passes.
(11:16:15 PM) Dakota G: I have a good resource here for using manual mode, and can be helpful for double checking settings: https://glowforge.com/support/topic/first-three-prints/working-with-manual-mode
(11:17:32 PM) Julie Ogle: I am having to turn off the machine after every cut to get an accurate image.
(11:18:20 PM) Dakota G: Are you using the set focus feature?
(11:18:42 PM) Julie Ogle: I have been working in man mode.
(11:18:49 PM) Julie Ogle: I have set focus but will try again.
(11:20:44 PM) Dakota G: Also, regarding the issue with varying intensities when cutting, we’re seeing this too, and the team is looking into it now.
The workaround is to use different settings. For example, using Proofgrade settings would avoid this problem.
Can you let me know if you see this issue when using Proofgrade settings?
(11:25:30 PM) Dakota G: Just to be sure I understand, can you elaborate on the issue with the images a bit more?
(11:27:08 PM) Julie Ogle: Let me try it
(11:28:30 PM) Julie Ogle: When you say proof grade do you mean choose something from the material drop down?
(11:28:38 PM) Dakota G: Yes.
(11:29:01 PM) Julie Ogle: ok hang on a sec.
(11:30:24 PM) Julie Ogle: This intensity is still messed up. I have a craft show on sat. This will prevent me from making my product.
(11:30:45 PM) Dakota G: Can you send me a photo of that print?
(11:31:12 PM) Julie Ogle: Visitor uploaded: 20191105_151813.jpg
URL: https://v2uploads.zopim.io/3/H/g/3Hg3gqxPVNW9b704k6rEGjn3PINLVWpg/7cadeda442f165238ffa113fb8000aad73a5ebe9.jpg
Type: image/jpeg
(11:31:36 PM) Julie Ogle: And it does it towards the end.
(11:31:49 PM) Dakota G: Is that the print you just did?
(11:31:55 PM) Julie Ogle: yes
(11:32:04 PM) Dakota G: Using the Proofgrade settings?
(11:32:09 PM) Julie Ogle: yes
(11:33:03 PM) Dakota G: Looking at the prints, it looks like manual settings were still used.
(11:34:26 PM) Dakota G: After you select from the dropdown, click on the print steps along the left side and make sure “Proofgrade cut” is selected.
(11:35:09 PM) Dakota G: If you see the manual settings window instead, click the little "back button in the upper corner of that window to get back to Proofgrade settings.
(11:35:54 PM) Julie Ogle: No manual window. Just says medium draftboard. No where to select proofgrade.
(11:36:08 PM) Dakota G: Can you send me a screenshot of what you see?
(11:38:49 PM) Dakota G: When you click on the thumbnail on the left of the workspace, does the window that open look like this?:
(11:38:50 PM) Julie Ogle: Visitor uploaded: Screen.JPG
URL: https://v2uploads.zopim.io/3/H/g/3Hg3gqxPVNW9b704k6rEGjn3PINLVWpg/d2a073b1b54d558e747db7356a66afdd37066a5a.jpg
Type: image/jpeg
(11:38:54 PM) Dakota G: Agent uploaded: Capture.PNG
URL: https://v2uploads.zopim.io/3/H/g/3Hg3gqxPVNW9b704k6rEGjn3PINLVWpg/a844d827146875aeb20d27af03ae7e2585e51533.png
Type: image/png
(11:39:14 PM) Julie Ogle: yes
(11:40:47 PM) Dakota G: Can you individually click on all the steps on the left side, and send me a screenshot of the window that pops out for each step?
(11:41:14 PM) Julie Ogle: At this point I will work with what I have while you send a new machine I do not have the time to mess with this.
(11:41:49 PM) Dakota G: I can have my senior associates follow up with you in email if you’d like. They will have better expertise.
(11:42:30 PM) Julie Ogle: No just send a new maching.
(11:42:33 PM) Julie Ogle: machine.
(11:42:45 PM) Julie Ogle: Too many issues and we are only working on one.
(11:43:41 PM) Julie Ogle: Visitor uploaded: Capture.JPG
URL: https://v2uploads.zopim.io/3/H/g/3Hg3gqxPVNW9b704k6rEGjn3PINLVWpg/f9df40c5ce0f6b778e67d53ec97eed5c7c83ffad.jpg
Type: image/jpeg
(11:43:51 PM) Julie Ogle: Last screen shot.
(11:45:03 PM) Dakota G: That does have manual settings. Please click on the “back” button in the upper left corner of that white window.
(11:45:13 PM) Dakota G: Then try a print one more time.
(11:45:30 PM) Julie Ogle: At design page.
(11:45:42 PM) Julie Ogle: Now what would you like me to do.
(11:46:08 PM) Julie Ogle: design library.
(11:46:22 PM) Dakota G: Agent uploaded: Capture.PNG
URL: https://v2uploads.zopim.io/3/H/g/3Hg3gqxPVNW9b704k6rEGjn3PINLVWpg/8bc73495ec3d48dff6e864846a00df52d93db1d8.png
Type: image/png
(11:46:59 PM) Julie Ogle: now what
(11:47:49 PM) Dakota G: Does that window look like this now?:
(11:47:54 PM) Julie Ogle: yes
(11:47:55 PM) Dakota G: Agent uploaded: a844d827146875aeb20d27af03ae7e2585e51533.png
URL: https://v2uploads.zopim.io/3/H/g/3Hg3gqxPVNW9b704k6rEGjn3PINLVWpg/8b8611f7aa5b1ad5a62095e6fa16de60958107d8.png
Type: image/png
(11:48:11 PM) Dakota G: Go ahead and try a test print one more time.
(11:48:29 PM) Julie Ogle: No it does not. It has my design on it.
(11:49:52 PM) Julie Ogle: Visitor uploaded: Capture.JPG
URL: https://v2uploads.zopim.io/3/H/g/3Hg3gqxPVNW9b704k6rEGjn3PINLVWpg/b865f971a8805da5780aee027fbe418439c402a4.jpg
Type: image/jpeg
(11:50:55 PM) Julie Ogle: 'no place to choose proof grade
(11:51:00 PM) Dakota G: Ah, ok, I see where we may be encountering a miscommunication.
(11:51:55 PM) Julie Ogle: ok?
(11:52:08 PM) Dakota G: Agent uploaded: b865f971a8805da5780aee027fbe418439c402a4.jpg
URL: https://v2uploads.zopim.io/3/H/g/3Hg3gqxPVNW9b704k6rEGjn3PINLVWpg/659f29987a3c5b8637ccda42fdd4f2354f4068cf.jpg
Type: image/jpeg
(11:52:37 PM) Julie Ogle: yep
(11:53:00 PM) Dakota G: The item I’ve selected in red is currently set to manual settings, if you click on that and then select the back button, you’ll then be in Proofgrade settings for that step.
(11:53:14 PM) Julie Ogle: Ok I see proof grade now. Let me try it…
(11:54:18 PM) Julie Ogle: Just went to cut and a different image of old wood showed up. Have to shut down machine be back.
(11:54:52 PM) Dakota G: Does opening and closing the lid refresh that image?
(11:54:58 PM) Julie Ogle: no
(11:55:03 PM) Julie Ogle: waiting for warm up.
(11:56:35 PM) Julie Ogle: been 3 hours and I have not been able to cut a thing for my show.
(11:56:43 PM) Julie Ogle: still waiting.
(11:57:08 PM) Dakota G: I understand, and I’m so sorry for the poor experience you’ve had. Let me know when you are able to do the print.
(11:58:03 PM) Julie Ogle: did you know when you hit the volume key on your key board the image on the forge gets smaller?
(12:00:35 AM) Dakota G: It may be different from keyboard to keyboard, but some keys can have more than one function. Your volume key may also be the zoom key.
(12:00:56 AM) Julie Ogle: Even more inconsistent than before. Working on sending pic.
(12:01:39 AM) Julie Ogle: Visitor uploaded: Proofgrade.jpg
URL: https://v2uploads.zopim.io/3/H/g/3Hg3gqxPVNW9b704k6rEGjn3PINLVWpg/15d399e27383aa427749af536e4f9c65c0cdea8b.jpg
Type: image/jpeg
(12:05:25 AM) Julie Ogle: I also have customers waiting on orders.
(12:05:58 AM) Dakota G: Thank you for trying that and sending that photo. Unfortunately this issue is outside of my scope of knowledge, but I will have our engineers look into this and follow up with you in email. Is julieogle99@gmail.com the best email to reach you at?
(12:07:18 AM) Julie Ogle: Yes. Can you also give them the laundry list of other things?
(12:08:22 AM) Dakota G: Yes, I’ll make sure all the details reach them. While I’m here, do you have any other questions for me today?
(12:08:49 AM) Julie Ogle: LOL We can stay here all night…One think or 5 things at a time…lol
(12:09:35 AM) Dakota G: Five is fine!
(12:09:57 AM) Julie Ogle: Ok I will wait to year from you.
(12:10:10 AM) Julie Ogle: From them
(12:10:38 AM) Dakota G: If any other questions arise in the meantime, feel free to reach back out. I hope you have a good rest of your evening, Julie!
(12:10:57 AM) Julie Ogle: ik
(12:11:04 AM) *** Dakota G left the chat ***
Type: image/jpeg
Type: image/jpeg
Type: image/png
Type: image/jpeg
Type: image/png
Type: image/png
Type: image/jpeg
Type: image/jpeg
Type: image/jpeg
