SO, i want to try and etch some aluminium scales, but im a noob att this
so i thought id ask about what settings to use, will the GF pick up the
slight curved surface?
You can’t etch aluminum directly. Unless it is anodized–in which case you will etch the coating off of the aluminum–you will need some sort of chemical to etch the surface. Try Moly-Lube, Cermark, or something like this:
they are anodized so i want to just etch off that so to say.
The continuous autofocus is not yet a feature of the Glowforge. I believe it is still a “to-do”.
The curved surface may still work depending on how much curvature you have and how tolerant you are of the result from having the beam somewhat defocused (fatter and less power) which will give it a faded blurry appearance to a degree varying with the distance from the lens.
