If I have a cut close to front right corner, the printer head is colliding with the magnet-bump-out of the front door and causes a miss alignment in the x-axis for the rest of the cut.
A short term workaround for the pattern you are working with would be to reduce the space between the individual pieces and move the whole thing “up” a bit. (I know – making a huge assumption here as I can’t see other end of the pieces. I could have figure & ground reversed.)
I think there must have been an update and the program has an error in calculating the distance to move the head.
I just turned on mine and it hit the front and then kept trying to go, so i shut it off, unplugged it. then move it back to home position top left and turn on again. I did the same thing and Back on during calibrating it hit the front door. Third time had no issues.
My guess is that GF is making software changes, with new bugs, and these are slipping through whatever QA process they have and getting out into the wild before they’ve been adequately tested.
Just a guess. I’m seeing multiple threads with strange, never-before-seen behavior, and the only explanation I could come up with is new software bugs.
I guess on the positive side, it at least indicates some forward momentum on the software front.
Well @dan for GF v2, there is a stepper motor driver chip that can detect a limit situation (i.e. stalled / motor not moving) electronically, with no requirement for limit switches and also to detect unplanned obstructions in the work area. They are using these on the new Prusa MK3 3D printer.
Thanks for your patience. We’ve found that this unit has an issue that we cannot solve remotely. I recommend we initiate a warranty replacement. I’m very sorry for the bad news.
