I’ve been trying to engrave photos on tiles for about 2 months now with near zero success. I had some pretty unsuccessful results using Rustoleum white spray paint and titanium dioxide/isopropyl alcohol approaches (norton white tile method). Now I’m investigating using wood glue as a mask and then applying acrylic paint/alcohol ink to the engraving. I’m using the convert to Dots setting for all of the photographs and images and I just don’t know how that’s gonna turn out when I do a flood fill with the acrylic paint and then try to clean the paint so that way the unengraved areas don’t have any paint on them. I’m really hoping to finally achieve some success with photo engraving on ceramic tile
I have been scouring the forum for months, following all the tips everyone is saying to do and am unable to get the results everyone else is getting. That’s why I’m trying this third approach where I’m literally just making a deep engraving and then filling it with black ink and letting the difference between engraved dots/unengraved areas produce the shading seen in the B&W photo.
Can anyone suggest tips or input on this approach?
I haven’t tried engraving photos on tile yet. But I do use the wood glue method for masking on acrylic and LOVE the way it works. I just let it dry before engraving, and let the paint dry slightly before peeling off the glue. If I let the paint dry completely, it tends to pull some of the paint off. But the glue is really easy to pick off with a straight pin in the tiny areas, and in larger areas can peel off in large chunks.
I have also found that with the tiles I have (I bought a lot of six different colors from a business going out of business), that it depends on the color of my particular tiles with how well they engrave. It’s all trial and error.
Just to be sure, you’re aware that it’s very binary. Either you remove the shiny coating of your tile or you don’t. The photos I’ve seen that look really great, the artist painted in all the colours and shading and they wouldn’t look anything like that if it were all one colour.
The whole thread I linked is filled with great info and examples.
My finished tile is here:
I have a Glowforge pro, which everyone who posted about the Norton tile method used, because the aura just came out and all of those forum posts are from a few years ago.
That’s the thing, tile is tile and techniques haven’t changed much. Engrave the tile, color it up, remove the excess. You can do that manually by scrubbing or via something more like a resist (wood glue, liquid latex, maybe even dish soap idk – is dish soap soluble in alcohol? Maybe alcohol ink and dish soap, but I suspect there’s water in alcohol ink, which would be bad for the soap idea)
In all the process is simple, and there are lots of ways to get there. Norton or other paint engrave is the fiddliest of them because it’s hard to be consistent in your paint layer.
I still can’t seem to get Titanium Dioxide to work. I either engrave and color with sharpie’s or get black tiles and spray paint them white and just take off the paint layer.
I watched a video on YT called Engrave Like A Pro - CERAMIC TILE = GLOWFORGE PROJECT |
by CRAFT FANATIC. He used the Vary Power setting instead of the dots.
Hope it helps with more ideas…
