- AC Infinity Cloudline S6 inline fan
- Two 6" to 4" adapters to add to the fan (mine are from Home Depot, but AC Infinity sells them now too)
- AC Infinity 4" flexible ducting
- Foil HVAC tape to seal up all the connections
- Window insert is two sheets of Proofgrade Clear Acrylic glued together to match the width of my window, spray painted white on the outside, and then I laser cut a hole in one side to attach a dryer vent cap like this, not sure which one I bought
- The ducting attaches to the Glowforge Mounted Blast Gate from the free files section of this forum so that everything can be kept hooked up to the window 24/7 without humidity/cold coming in when not in use
