I’ve looked through a bunch of posts and just want a simple answer if it is simple. I want to engrave in a cutting board to thick for the tray so when I remove it do I need to change any settings or will my pro do that for me ? Thank you
You will not need to change your settings if you get the cutting board to within 1/2" of the laser head.
All the posts are teaching you how to get it to the correct height.
There are also a number of people selling supports on Etsy. You can opt for a svg. and make them yourself or get some plastic ones for a few dollars more.
You might also find this handy. It gives you the actual focus height. I came up with it because that was hard to determine on glass without putting tape or similar onto the surface.
