That is really beautiful. Nice job!
Very nice, maps are on my to do list.
Gorgeous!
Thatās awesome! Looks beautiful!
Geographer here ⦠how big and how long?
I ran this one smaller than I intend when I make the final version for framing. Here it is, weeded and on a sheet of 8.5x11 for scale. The print took 1hr 9min if memory serves. The smallest text is almost legible, will be great when I print at max bed size. I bet had I upped the lines per inch settings, even at this size it would work.
The map is from 1859. I have an even earlier map, before Aerizona was separated from New Mexico, that will be part of this project. I found these and many more when digging through our public domain archives.
So cool! Love the map projects!
Here is a free map resource from National Geographic. Free signup is required.
if you donāt want to sign up, you can get maps straight from the USGS (i think thatās where theyāre pulling everything from)
Comically the last one for my town is 1893⦠Signed off on in 1901.
Anniversary gift for my parents. The photo does not do it justice. Only part I am not totally happy with is the zia. I should have used a fill rather than a stroke. I used a thin wash of black acrylic paint to darken the engrave.
Outstanding! You are really doing a number of very nice projects. I still have not tried any type of rockāI really need to do that.
Just had a great meet up with @Hirudin. Somehow we managed to spend 5hrs experimenting with the Glowforge but it seemed like much less. We went in a direction I had not headed yet and it was a great learning experience for me. I will let him give the details but I am pretty sure one of our tests was a Glowforge first!
He left me with this amazing bottle cap opener he fabricated and powder coated. Looks amazing!
Iām glad someone tried this before I did⦠Iāve been looking towards recycling aluminum cans for instrumentation backplates (it would save me a lot of time in needing to flatten billets), and was thinking about powder-coating them and then laser etching the results.
For the record, the cool bottle opener was something @Hirudin made on his CBC. He did bring some powder coated laser etched samples that were wonderful.
My oldest daughter wanted to make some jewlery from start to finish. I put her down in front of AutoCAD.
After a bit, this is what she had done.
I did provide some basics in AutoCAD, and we went through the process for non Proofgrade, but the rest was all her!
Sweet! Nice smile and cool design. Makes me think of making a grape cluster as an earring. Would look nice like this.
Fantastic! Sheās a natural! Love the dog photobomb too.
I really like those! (A designer is born!)
Yeah, it really didnāt seem like 5 hours! Time flies when youāre having fun.
Well, I tried to resist saying it, but the Glowforge really is bigger in person. And this is coming from someone who already owns a laser cutter with a very similar width as the Glowforge (within 1 inch). And it really is a sleek lookinā machine; it looks better in person as well, IMO.
So⦠letās see, what did we do that whole time? I guess if I was a better planner I would have made up a list of things I would like to see done on a Glowforge before I got there. Instead, I basically grabbed a bunch of random laser-related objects that were within my reach while I headed out the door.
A couple of the things I grabbed were two thick pieces of acrylic that Iāve been kicking around for several years (5 maybe). One of them was about 11.5mm (~29/64") thick and the other was 18mm (~45/64"). After messing around with some kerf-gauging squares for a while (which I mis-remembered how to make) we decided to put the 11.5mm piece in there, just to see what would happen. Not wanting to waste too much time, we cranked the power all the way up and turned the speed all the way down (100% / 4 IPM) and loaded up a small circle to do a test cut. We were surprised/disappointed to see that we couldnāt turn the speed to anything lower than 4 IPM. Oh, we also set it to do 2 passes. We sent the job to Glowforge and waited to hit the print button. To both of our surprise, it cut through on the first pass! It looked like it was making a pretty darn nice lookinā cut too! Of course, it then continued on to the second pass which seemed to do little other than mark up the bottom with flashback. The small plug of acrylic sorta melted/solidified into the hole so it didnāt drop free after the cut was finished but it didnāt take too much to push it out.
Hereās a pic of the top of the hole.
And one of the bottom (with the flashback). I suspect this would have looked nearly as good as the top if it werenāt for that second pass.
So, hot on the heals of that success, we decided to go right to the 18mm stuff. Of course, this necessitated taking out the crumb tray and we used some hardboard scraps to lift it high enough so that it was in the focus range of the laser. We put a tile underneath to try to curb any flashback. Not wanting to only do a circle again, we scrambled to come up with a vector file that @chevalier_jeanpaul had on-hand already. Why not⦠a Glowforge logo?! We loaded it up and used the same settings as before (most powerful, slowest speed (100/4) with two passes). Once again, to our surprise, it seemed like it was cutting all the way through on the first pass. This time the cut quality was definitely suffering though. Curved striations, the ones that are indicative of the head moving too fast) were very apparent toward the bottom of the cut. Nevertheless, we let it continue. Pass 1 finished and pass 2 started. When it finished, the area around the cut was definitely pretty hot and the āGā was stuck in there pretty good from the melting/solidifying like we saw with the circular plug. With enough fiddling and pressing it did eventually come out. The edge quality definitely could have been better, but nobody ever said it would cut ~3/4" acrylic so even I canāt complain too much about that.
Pretty pleased with our relative success, we decided to cut out a big one to use up most of the rest of that piece of acrylic. The theory was that the thicker sections of the larger piece would hold up the heat better and possibly not melt/solidify as much. In an additional attempt to make it easier to get the āGā out of the stock, we also broke up some of the internal sections with some extra lines, one of which spanned the gap between the point of the round part of the āGā with the square part of the āGā. Something like thisā¦
I decided these extra lines should be cut first - that was a mistake. The Glowforge dutifully cut the āhelpingā lines first and then went on to do the āGā shape. The first pass finished and the second pass started lasing around the outside perimeter for the second time and once it reached that ābadā line, the āGā fell onto the tile that we put in earlier. We managed to lift it back up, through the teardrop-shaped hole left in the material, and rested it down onto a couple more pieces of stacked hardboard. Without much to lose at this point we fired the job back up in the hopes that we hadnāt shifted anything. I guess we did a pretty good job because this āsecond and a halfā pass seemed to trace over the original(s) pretty accurately. Unfortunately, the hardboard we stuck under the partially cut logo ended up discoloring the bottom when the laser passed through those areas.
Hereās the two "G"s sitting on the floor of the Lumosforge, with the stock behind them. Check out how much that thick stuff refracts the edge of the metal plate!
Another angleā¦
And hereās one of the middle pieces (tinted yellow in the non-photo image above) with a couple rulers for scale.
Anywho, this post is long enough. We did some other stuff too, but this post is already pretty wordy as it is.
