This is not an automatic function of the Glowforge software. Likely either you mistakenly scaled the object in the GFUI as you were attempting to move it, or your SVG is set to an unexpected DPI making it appear to be scaled.
It’s really difficult to sift through all of the color you’ve added. It’s difficult to tell if you actually want help with the cutting issue or if you just want help selling the unit. So if you could make your desire clear I’d be happy to help with either.
Regardless, I didn’t see… What application did you design this in?
I’ve never had a svg resized. I’ve resized an svg using the GFUI by accident, but I can’t believe you would have done that and not noticed it. I have heard about resizing issues when exporting from Inkscape. I believe those issues are all related to using bitmaps instead of vectors for sizing. In that case it is an Inkscape-dpi-Save As issue.
Some of your issues are being reported by many other users and those were caused by pushing a bad software update. Some appear to be you did it this way in your file and it needs to be done that way. Your other issues could be a user issue or an instrument issue. As this thread has jumped all over the place I would open up a separate thread with the specific issue(s) in the OP or just email support.
You could ask for help here regarding design and have assistance in under 5 minutes.
Yes, that I could, but this should be a simple process according to Dan and all his demos over the last 1.5 years or so. So my background being in tech I want to do it the Nerd way to find issues better.
Anyhow, I just re-saved the wing rib to PDF. Tom_A I found out why I could not select the holes. The vector image had been dropped in an area that did not have plywood so was a black background over the crumb trey. I was finally able to select the four objects and drag them down to my strip of ply that I was testing on. With the PDF file, I was able to cut to almost scale. The rib came out a 1/4" more in length. The main body is perfect so it may be that I had changed the original file. Forgot to mention that I have a previously cut rib for comparison.
If GF can fix the random drop outs and speed up scanning along with fixing the basic app then this machine does have great potential for the future.
My feeling is that GF is not using a Gui Designer. My past dictated that hands on software engineers should not be designing the user interface due to the thought process being slanted to knowing the code. This App just reeks of lack of flow and good GUI design principles. Then again maybe I’m just picky and expect a production product to be working.
Just do a google search for bricked Muse and I think you would have a different opinion on that.
Plus I think you will find out shortly how much better the Glowforge customer service is compared to FS. They will have you up and running ASAP. Where FS would somehow find a way to say the issues was your fault.
All of my parts are coming out to a tolerance I can’t reliably measure. A 1/4" is way beyond acceptable. So I suspect the file as well.
I 100% agree that software engineers should not design GUI’s, but I’ve never seen a design everyone loves. The software is still in beta, and we all accepted knowing that, so at the moment only the hardware is production.
Something’s wrong. If you don’t mind, post the file so it can be validated. Also, you might want to go with an SVG rather than a PDF. Again, what app did you design this in?
As for the GUI… It’s functional. Definitely not pretty. Frankly, it doesn’t do much, so there’s not much need for much more than it is. You do all your design work in your design application. The GUI is really only a step or two above being the equivalent of a printer driver. It does what it needs to, basically, and that’s it.
Considering what other people can (& have been doing for months) perhaps a more accurate statement would be “unusable by me” which is a totally different thing.
There are a lot of tutorials here and all you have to do is post a question if you need help and there’s a whole bunch of folks who can help out.
I design my work in SolidWorks, export to PDF, and import the PDF into the GFUI. My accuracy is within 0.005 inches on every cut so far and many of them are dead on. I suspect the problem with sizing is the source file and not the laser unless there is something really wrong with the hardware you received.
Not so… Yes, after messing around for a while it can be made usable once you find the weird stuff and figure work arounds. Now that I have found a few issues I have been working around them and have been able to make a few cuts.
Tom… regarding the SVG. That I’m investigating. I have never had an issue on other lasers with SVG files so that one is a little strange. I use Intaglio for vector design with no past issues. I have also saved and cut files from EPS format with great results but the GF does not do EPS.
One of the main reasons to get the GF is to prototype rapid parts test fit. A lot of times I have to draw with pencil on wood or whatever then cut out and test fit prior to creating a permanent vector file for production parts. So now I have been messing with the trace function which is not very well explained. In this function I do not want to engrave anything I just want a clean cut. By clicking inside or outside of the trace line I have finally been able to get it to work. Only caveat here is it takes so bloody long to scan and prep that many times I could hand cut it faster. So I’m hoping that they can get the scan and prep really speeded up.
Enclosed is a link for some of my work now that I’m retired. You will see that I am not some idiot who does not have any skills. This link may explain why I have to be somewhat picky in my choice of lasers.
BTW… I thank all of you for the continuing input. It really helps get ones head around these glitches and actually get something done. After some minor success I can see that the GF could be a great tool if the folks can get a lot of fixes done. Anyone know when a possible pass through capability will be in place?
I’m not familiar with Intaglio, but I know that you have to be careful when saving/exporting SVGs with other programs to make sure it doesn’t resize the output. Here’s an example for Illustrator:
There may not be an equivalent setting in Intaglio, but it probably wouldn’t hurt to check.
Best of luck then. Probably not worth asking for help as most of us can’t help since we didn’t have to overcome the unusable software - or we didn’t realize we couldn’t do what we were with it.
quote=“jamesaellis1, post:49, topic:13890”]
[/quote]
The automatic alignment feature is not there and there is no date for future improvements so it’s anyone’s guess. But the same techniques that work for indexing CNC jobs work with the GF.
I learned how to do it from ShopBot. There are a couple of their vids out there that cover it. Once you get it, it’s no big deal. Lots of good crossover techniques between CNC and lasers.
I have never had parts come out cut to the wrong size, and I have cut hundreds of pieces over the past few months. Any issues I have ever run into were caused by bad files. I would double check the scale in the file you are using, something could be off. Plus I would also run tests with a new file and a few squares set a couple of different sizes. If they could out as anything other then the size you set minus kerf then you might have a bad unit and they can work on fixing it.
Some have had some issues. But many of yours seem unique. As you’ve stated, you’ve been having issues with the most basic of tasks. That’s just not typical. So “usable by me” seems like the best statement.
I’ve never even heard of this Intaglio, but now that I’ve looked it up I see it’s a Mac-only app so maybe it would have passed me by. You’re definitely the first Glowforge owner I’ve heard using it. You might want to check out Inkscape as it’s feature-rich, free, and used by many who can help you with the myriad issues you seem to be encountering.
Again, it will be helpful if you upload the file here so we can see why it wasn’t sized as you expected.
Tom… I tried Inkscape and do not care for it that much. I have years of designs invested so reluctant to change apps.
Have you tried drawing on a bit of plywood then scan and be able to cut it without the App giving an error message that something is wrong. If I draw, scan and do the white space thing. Then it sought of works except the lines are engraved prior to cutting. I zoomed in and removed the outside purple line leaving just one which I assumed would simply cut. In other words I left no image to engrave but just the a single purple line that should be a cut line. I also tried it with just the inside line I get the error with either choice. It seems that the trace feature must be able to engrave prior to cutting.
Later today I’ll spend some time on the demo stuff from other folks and see what they are up to.
SVG files commonly don’t have real units (inches, millimeters, etc.) attached to them. Because they were originally designed for web use, they use “user units” by default, which software is free to scale to any size.
Some software can be told to use real units when exporting SVGs. E.g., in Adobe Illustrator make sure the “responsive” checkbox is NOT checked.
Some other software doesn’t have any way to set real sizes for SVG export. Affinity Designer, for example, sets the size to “100% 100%” (meaning “scale this to fill the window”) when “Set viewBox” is checked and the size in pixels (using whatever DPI you’ve set for the document) if the option isn’t set.
I tend to export to PDF when possible, as PDFs always use real units for page size (although a few oddball programs manage to mess that up) so the Glowforge always has real sizes to work with. (Of course there are currently a few other problems with PDFs on the Glowforge, such as issues with clip paths not being supported, but that should be fixed someday.)
When I must use SVG files from programs that don’t export SVG with real units for the height/width I do one (or more) of the following things to work around the problem:
Set the DPI to 96. This is the DPI that Glowforge assumes. (If I’m remembering correctly.)
Set the size of my document to 20" by 12". Even if it’s exported with the wrong size, anything with this aspect ratio automatically shows up as 20"x12" in the GFUI as a special case.
Manually edit the SVG file to add proper dimensions to the height/width attributes on the <svg> element.
