*SOLVED* Help with anodized and powder coated aluminum
Hello!
I purchased the Glowforge to engrave on powder coated aluminum and anodized aluminum.
I’m happy with the detail of the first test engravings, but I can’t quite seem to get it to be that nice bright aluminum color that some of you are getting. The steering wheel plate is the powder coated plate and the mousepad is anodized aluminum. The powder coat is much thicker than the anodize.
artwork is an svg exported from illustrator
IMG_20190222_164011
Settings:
200 speed
100power
450dpi
tried 1 pass and it was too dark. 2 pass and it’s a little better, but still dark.
Any advise?
Thanks!
I find that I have to wipe down metal engraves afterward with a good solvent. Try windex or alcohol and see if it brightens.
I used acetone and that did seem to help a bit. One thing I’m wondering is if I take more time to prep the aluminum before anodizing and get a perfectly smooth finish, that the engraving will look better.
Will keep testing and share my results
Anodized aluminum can vary a lot, as you seem to be aware. But I wonder why you’re going to slowly? Every single anodized aluminum item I’ve done I’ve done at 1000/100. I wonder if, by going so slowly, you’re possibly scorching the coating or the aluminum, making it darker. I’d recommend just doing some basic testing… A small shape at 1000/100/450, 900/100/450, 800/100/450, and so on. Then, without taking out your test material, you can take a look and see your result. If you want to, you can then do a 2nd pass on the whole thing and see your results there.
I agree with @Tom_A. Hot and fast. I’d go 1000/full/270 to start. 400+ lpi is probably overkill.
Anodized aluminum is one of the only materials I’ve tried that looks better at higher LPI. It removes any possible trace of overlap or anything caused by even the tracest amount of variation in image, power or anodization.
I totally agree that higher is good but 400+? Defocus by 0.03 if you want to smooth it out a bit. The time for high lpi isn’t worth it IMO.
SOLVED! Newbie mistake :rofl: I had the power down to 10% thinking it was 100%
Middle is 10% 400 speed 2 passes, bottom is 3 passes
Top is 400 speed, max power, 2 passes. Then used Acetone and a rag to clean it up.
The big thing about getting that finish was sanding the aluminum to 2000 grit and then using a buffing wheel to get a mirror finish on the aluminum. I then powder coated it and running it at full power gave an AMAZING engraving! Very happy
Oh wow, that looks so much better!
I agree with this.
I don’t do enough aluminum, but what about a lower lpi slightly defocused and then a cleanup score?
I’ve never tried that, so I can’t argue that. I can however vouch for the difference between low and high DPI. I’ve done quite a lot of anodized stuff, but the items are relatively so small that length of time to engrave has never been an issue…and one small step less than your idea. Maybe sometime I’ll try your idea, though. Always fun to test things.
Speaking of defocusing…I’m very interested in that concept…but, mostly for acrylic. I’ve read a little about it here on the forum, but there’s really not a lot to read. My question now is…how does one know how much to defocus? …and in which direction? Or does direction matter?
Generally I refocus above the material. If you do below the beam is still converging and gets tighter as it works through the material (in theory).
Probably not an issue with aluminum where you don’t remove anything.
The other day I read .25" defocus to .433 …then today I read a different one, .125 to .03. I don’t see any rhyme nor reason to it, but if there is I sure would appreciate hearing what it is. And these numbers were both with acrylic.
This was where I was first reading;
takitus
Jun '17
@davidgal2 It was .25" so I had to set it to .433". Worked better than I thought it would!
As I said it’s in theory.
The beam is an hourglass with the focus in the middle.
If the focal point is above the material it’s on the “bottom” of the hourglass and is progressively getting wider, and therefore less intense.
If the opposite, then the beam is still getting more intense as it approaches the focal point.
It seems to me that as you remove material therefore it’ll be increasing or decreasing the intensity as the engrave gets deeper.
This effect might be completely negligible in all materials, and certainly is when engraving something where no material is removed (aluminum), but (in theory) the two setting could have different final effects in many materials where the engrave has some depth.
My gut says the difference will be undetectable but the two settings are definitely not the same in terms of what’s happening with the laser.
For Acrylic I defocus to the max I can enter in the field (.5" iirc) in the operation - I’m overriding the material setting. The material setting stays as the true thickness if the material (generally 1/8 or 1/4") so I can get a good bed image and the cut focal length will be correct.
Do you wipe down the item with Solvent before or after the engraving. Thanks
I did a defocusing test yesterday…on medium PG clear acrylic, using both the ‘above’ and below settings. The .5 setting gave me the best outcome, however…the engraved parts looked sort of yellow compared to what engraved acrylic normally looks like…the frosty white. I did a bit of cleaning on it which improve it, but I’d like to know why that happened?
