I’m engraving anodized dog tags. Some vectors Are allowing full power. Some victors are not. I have done test with similar images with no issue before the update just for history sake.
Here you can see this logo engraves great. It is vector SVG.
I thought it might be dirty so I clean the entire machine. And tested again.
I tried an image with the dots in all different settings and still the same result you can barely see it. I can tell by the being hitting the anodizing That it was nowhere near full power. I even slowed it down to speed 200 and you get see almost nothing.
Just to make sure it wasn’t the laser itself and it is indeed the vectors and the software I tested a simple star which has very fine points to also testif its a width of line issue. It engraved perfectly.
This is not the laser. This is not the material. This issue lies with the software or the vectors. But I highly doubt it’s the vectors since I tested both true vector and raster
With clues from the other person’s topic with similar issues, I believe I have pin pointed the software bug. This IS a change and it IS a bug.
The svg file is set up with 2 overlapping engravings so that I can flip it over and engrave the second side without aligning anything.
First side=
Ignore second engraving
Engrave first.
Second side =
Ignore first engraving
Engrave second.
The image that is below the first, even though the first is ignored, is not allowing the engraving to happen. The ignored is acting as a block. Either just reducing power output, or stopping it all together.
i haven’t seen the issue you’re talking about when the objects are different colors and thus different operations. only when it’s the exact same object (same fill/stroke colors) directly on top of each other so they’re both in the same operation.
FWIW, I’ve done a file just like this in the last week, and had no issue.
When did it start?
I’ll try to find some time later today to test mine and see if there is an issue now.
Here is a file with 2 tests. one with vector. one with raster. The power variation is noticeable with anodized aluminum. please use that to recreate. wood takes so little power in comparison that I’m not sure it would have the same affect. but I guess you could try and see what happens
engrave one of the overlapping images with the other ignored, then switch which is ignored and test again on the other side of the material or a different location.
You’re doing a whole lot of testing with different files, asking questions about the results, suspect the vectors are the problem, but no one can verify or look further into it without the actual file that you’re using.
No one even knows for sure what settings you’re really using… I see one recent screenshot with some settings (speed/power but it would be helpful to see what you’re doing with the actual engrave settings as well).
