I am trying to find a stand for a small round of clay that has a memorial paw print on it and the stand/easle design I currently have even at it’s smallest size option is too big and the bottom of the round winds up hitting the surface the stand is on so the round won’t seat correctly. The round is just around 3 inches across so need a fairly small stand. I was hoping somebody knew of some plans that might work. I appreciate any direction. Thanks Mike
thank you. I will see if any will work. the first one is different styling than the one I have and will need to see if that one will maybe work. The others are similar to what i have and while they have worked great for me for other things, this was not fitting properly. thank you again!
