I have had my glowforge for sometime now, but I have been having issues attempting to design anything. I have tried Inkscape but honestly it is a bit overwhelming. I have created other designs through my Silhouette Studio but I can not seem to figure out how to create my own design with Inkscape or even trying to change my .studio files to .svg. All of the designs I upload say that they can only engrave, but I can never cut.
I know my way around Illustrator, SCAL, and Make-The-Cut… and I found Inkscape to be absolutely infuriating. I had to look up how to do every last little thing. So, you aren’t alone these.
Since you know Silhouette Studio I would first try to figure out saving SVGs from there. If no luck, or if you want to try something new, I would look at Affinity Designer. It is $50, but it very pleasant to use compared to Inkscape. It has many fans here and you can get a lot of help.
Welcome to the forum, @hillarymhendrix. Inkscape can be overwhelming, with so many more choices and options and features. Silhouette Studio is much simpler, but you have learned the basics of vector designing if you can use it. Silhouette Studio can save a design file as an SVG only if you have an upgraded version. It costs to have that feature.
If you are only getting engravable objects, then you have might have filled the object with a color rather than defining the stroke color only.
Have you done the First Prints tutorial yet? It does walk you though the process using Inkscape.
Have you noticed the Glowforge Tips and Tricks category? There are many tutorials there, including the basics of Inkscape that can help you understand how to design using vector software.
I will probably end up paying for the upgraded version then since I am already familiar with the software. So the trick is to make my image dark then leaving the engraved area blank? Like a black circle with a phrase within it, but the phrase have no color? If that makes sense.
Honestly, just commit to Inkscape. It’s not impossible, and it’s not even counter intuitive once you understand vectors. You can use simpler programs, sure, but you’ll eventually be like “why doesn’t my simple program do X or Y?” That’s because you’ve outgrown it. You won’t outgrow Inkscape.
They’re for a slightly older version of inkscape so occasionally you have to figure out what menu things are in, but it’s thorough and really simple.
It’s a little more complicated than that. I don’t have my Silhouette software loaded on this computer at the moment, so I can’t recall if you can fill a shape. The Silhouette is only going to give you vector lines to cut and no fills that would be necessary for text.
I am with @evansd2 in that Inkscape is very powerful and useful and there are tons of tutorials. One helpful thing is to tweak the size of the icons in preferences to you can see them and menu items more easily.
A vector path is a line that when it has a defined color, will default to a cut. If that same shape, such as a circle, has a filled color, that will engrave, as long as the outline of the shape, which is the bounding path, does not have a defined color.
To engrave text, you have to make sure the text (which is a special object that can be edited using text functions such as size and font choice) gets turned into paths (which is a special object that can be edited with normal object functions). Text that is to be engraved doesn’t have a defined color to its bounding vector path. It gets converted to a path object and generally has a fill color.
When the Glowforge imports it, then it interprets each object as either a path to be cut/scored or a filled object to be engraved.
Some folks like Affinity Designer. It costs, but less than Illustrator and it seems more user friendly at the start.
Yes and no. If you want text to stand proud and un-engraved within a deeper background shape that has been engraved, you can’t just pop an unfilled object of text on top of a black background filled shaped. You have to “punch out” the text so that the text and the background object is on thing.
This is what I think you are trying to do. It’s an SVG. You can right click and save as and then open in Inkscape and see how it is made up.
And since the original post is “Best Programs”
Search using the term software instead of program.
The most common are Affinity Design, Corel Draw, Illustrator, and Inkscape, While some folks use 3D design programs like Fusion 360, almost everyone here uses one of these four programs.
It is a a challenge, but well worth it. I had familiarity with Inkscape, but had to learn how to design specifically for the laser. Then I wanted to learn a 3D design program, for designing things with the Glowforge but most importantly for designing for a 3D printer. I had tried numerous times to figure out how to start on Fusion 360. But then I tried OnShape and it clicked for me. Spent a long weekend learning how to do an object that was a simple shelf with three parts, but it was so worth it.
Thank you all so much for your help, I will have to sit down and see what works best for me. I know it is a learning process, just every time I get that bit of down time I attempt to design something, but I do not give myself enough time for trial and error. I think this will be something I need to dedicate some time to until I get it right.
Design always takes the longest time. You can start small, like use a box generator to make a nice simple box… and then put a image that you like as an engrave on the top. Easy assembly of elements like that will get you the basics of alignment and design pretty quickly.
Try some of the free svg sites to get a headstart, like openclipart or svgsilh. Then for box generators, there are a ton of them, but lately when I want a simple box I use this one:
Until I purchased my Glowforge I had never looked at Inkscape, but since I knew I would be waiting for months I setup Inkscape and just wandered around making stuff (most useless) but each step of the way I learned something new about how stuff worked.
It is a basic fact of the universe and computers that in order to make any decision about what you are doing there needs to be a widget to do so. The more control you have of the decisions the more complex the widget. The real learning curve is the organization and location of the widgets which is much less scary than trying to wrap your head around all the concepts.
I had already learned Autocad, 3D Max, Gimp, Corel, and Blender and mostly taught myself those with the same Widget approach.
I can remember the exact time I discovered nodes and curve handles on vectors. I was using Corel Draw. It was at least 25 years ago. I was designing a label for some homebrew. It was a California steam beer analog.
I didn’t know they existed. They are so small and back then with a small CRT monitor and low resolution very hard to see. And trying to figure out what those handles did and the different kinds.
But that is a key concept for designing vectors and is something that has to be learned.
I started with Corel Daw 3. Was very excited when they went 3D and then they killed the capability I was really pushing to do more 3d at that time, including several “flash in the pan” programs including “Trispectives”
