Does anyone know the best setting to cut inkjet art paper 285GSM on a glowforge ?
As all providers aren’t going to offer identical results, suggest you use this as an opportunity to get familiar with custom settings and testing.
285 is about 100lb, which is pretty heavy, but I recently used the provided settings on some heavy brown paper and I don’t recall being necessary to change them. If I did, however, I would have just bumped up the power a little and run a small test cut. That’s such a habit now for virually any material that I don’t give it a second thought. My test file stays near the top of My Designs…
This is good advice, for a link that gets into how to actually do some of that testing check out number six on the FAQ
Moving to “Beyond the Manual” as is the need for what is not psrt of the Manual.
