I have a Glowforge Plus HD. I would like to engrave a bamboo top from the top of a glass food dish found at TJ Maxx. It is about 0.48 inches in height. I think I can set it on the crumb tray to engrave but I do not know the manual settings to use. I have searched and find settings for the original Glowforge HD. Being that the HD Plus has updated power, can someone tell me what settings to use?
There is an often-quoted FAQ around here somewhere that talks about how to determine the settings for non-standard materials.
It all comes down to - testing to find what works for your material. Nobody has the precise material you have, but there is often enough “wiggle room” for near enough to be sufficient.
Start with settings for a similar material - either ones from Glowforge “proofgrade”, or something others have found works. Then adjust as necessary. If you start at lower power or higher speed, you reduce the risk of over-doing it on your first pass.
I don’t bother keeping records because it’s pointless. I’ve worked with many different pieces of bamboo, and never used the same settings twice - even on (for example) different cutting boards from the same package.
Welcome to the forum.
Bamboo is a rather variable material as it is not actually wood, but is grass. There are quite a few discussions about engraving bamboo here in the forum which may help. You can certainly use the settings provided here in the forum as beginning points for your tests.
As with all non Proofgrade materials, you will need to do some testing to determine the settings that provide the depth you desire. Even though you have the HD, it is still a 40 watt laser - the same as the Glowforge Basic/Plus.
See #6.
Thanks.
Don’t forget that if you don’t move your engraved piece you can make a second or third pass exactly on top of the original if it isn’t as dark as you want. ![]()
