What settings would I use for hard plastic? I’ve been asked to engrave on a rectangular non-glow on-off electrical switch. Thank you.
Hey welcome to the forum.
All of your questions about materials can be answered here in number four which talks about which materials might be dangerous and then number six which talks about settings:
Most switch plate covers are made of either polycarbonate or thermoset plastic.
Polycarbonate tends to melt and is really hard to work with, but thermoset plastic contains chlorine, so should be avoided at all cost! Chlorine gas will destroy your Glowforge’s electronics in short order.
Identifying the material is the most important consideration, so checking @evansd2 link referenced above is critically important.
Virtually none of the commercially available switch plates are going to be engraveable. You might consider some kind of veneer applied to it.
May suggest to them wood plates. Readily available at most big box stores.
Thank you for the information.
I tried it way back when and the results were underwhelming
OTOH, spray painting it with a colour, and then engraving off just the colour looks brilliant.
Thank you for the feedback.
| deirdrebeth Regular
November 12 |
Light switch cover questions Everything Else
Yes…and it melted. I found one that was made of laser safe material and ran a test on it. The laser caramelized the white plastic and the fan blew it lightly so it set in ~slight~ waves. It was interesting, and possibly useful if you were doing a design that took that into account, but I moved onto wood ones. They just looked better. [IMG_20181226_211726786]
Here’s a solution similar to what I’ve used, I never posted mine here but what I did was actually make two different-sized layers, a bit like a reverse picture frame, so I could cut holes in the room-facing side to allow the screws to be recessed. I positioned the design so I could use screws with black heads so they blended in to the design.
