I’ve gently tried to nudge it back to the rails, but it seems like it will take a bit more umph than I’m willing to give it without some official feedback.
The laser/head are crooked, and off the rails on the right side.
I have not experienced this however there have been multiple posts of this issue. It is usually fixed by turning of the Glowforge, and then resetting it all to the back. Then powering it on and letting it recalibrate.
Deep breath, it’s OK. The bottom wheel on that mechanism is spring loaded (standard design on any CNC), you can put it back on the rail without breaking anything. The question is what happened.
I did that once when I inadvertently had the material too far right on top of that ridge on the side of the tray, and the gantry jammed on it. Scared the h*ll out of me.
Was there any little pieces or dust build up in the track? I have noticed that it gets really dirty and small pieces end up all over sometimes in mine.
Make certain the tray is sitting all the way into the (clean) dimples on the bottom.
Thanks for reaching out. I’m sorry for the scare!
Is it possible something in your Glowforge blocked your laser arm from moving? Please check around the rails for any obstructions. If there aren’t any, could you please do the following for me?
Would you let us know how it goes?
OMG it’s the 3rd time i’ve turned on the machine and this scared the ***** out of me. Thanks for posting, so I can have this fixed and back running within 10 mintues.
Had the same, seems to work OK now.
Fixed! Gentle nudging, bit by bit (did not want to ‘force’ anything). The instructions were good. Not touching the tube, just gripping the metal bar. It popped back on. Once it was on track, it moved back and forth just fine. Everything to center and we did a successful test print.
#Relief
Sorry for the delay in response. I swear, if I’m just about to leave town, something happens with my GF. It’s enough for me to call cut off dates three days before I leave.
I’m glad to hear it - happy printing!
