Upon somewhat popular demand I offer this design for free:
You can use just one layer of . Alter the file a little and flip to the other side to run the other side. The only thing that doesn’t look right is the knob on the side - that really needs the extra depth. On the other hand the thread etc. looks better in one layer.
Make sure you set the black lines to cut; the green things to engrave; and the red lines to score.
Will work with a pin on back for one layer, or thread a necklace through the handle.
Tip: the scissors also make nice earrings; just copy and enlarge them a bit.
Edit:
Tip: in order not to loose the tiny pieces falling down the tray, before you lift the sheet, grab a piece of scotch tape and gently rub it on the small pieces. They’ll lift right out.
ahhhhhhhh! i was admiring your miniatures in the other post, and was hoping you’d have this one available for purchase! thank you soooooooo much for this. my mom is a quilter and a seamstress in general, and i want to make these for her quilting group.
