Stuck on "Calibrating"
#1
Hello Forum,
I have been struggling with my GF all day and have tired basically everything that is suggested in the other post linked below.
any other advice would be very helpful I am in production mode for a convention so this will hurt my bottom line.
Thanks in advance.
Jarret
Update Request
#2
I am also having this problem prior to the unit not calibrating but don’t think they are related.
#3
First thing to try is to turn off the machine and log out of the app, especially if you have it open on more than one device.
While the machine is turned off, clean the lid camera with a Zeiss wipe.
Then turn the machine back on and let it completely finish the startup calibrations and the head return to the home position in the upper lefthand corner before you log back into the app.
If it’s still stuck, you can try rebooting the router, and computer, clear the cache, and if all else fails, reset the Wifi connection. You might have to move the router closer to the Glowforge, or establish a stronger signal some way…when it gets hung up calibrating I believe it is usually a sketchy Wifi signal.
Instructions from the Troubleshooting section on it are here:
1. Restart all the devices
Turn off the computer, phone, or tablet that you’re using
Turn off your Glowforge
Unplug your modem
Unplug your Wi-Fi access point
Wait one minute, then plug everything back in and turn them back on
2. Improve the signal path between your Glowforge and your Wi-Fi access point
Wi-Fi signals need a clear path. Remove physical barriers, and move devices closer together:
Move your Wi-Fi access point up high and make sure it’s in an open space. Avoid locating your Wi-Fi access point on the ground, under a desk, in a cabinet, or in a corner where its signal can be blocked.
Relocate your Wi-Fi access point closer to your Glowforge
Move your Glowforge closer to your Wi-Fi access point
Install a Wi-Fi range extender closer to your Glowforge
Run an ethernet cable and install a second Wi-Fi access point next to your Glowforge
3. Reduce electronic and Wi-Fi interference
#4
Thanks I will give it a try.
#5
Thanks for reaching out. Unfortunately, it looks like your unit is experiencing an issue that we can’t resolve remotely. I want you to have a reliable unit, so I’m recommending we replace this one. I’ll be in touch via email to sort out the details. I’m so sorry about the bad news.
closed #6
