Hi all - Anyone ever have this issue? I am importing my SVG and when it renders it leaves out some areas - or should I say fills in some areas - in other words it does not render properly.
I create my SVG in Affinity Designer. I flatten and convert to curves the entire document. I export using my SVG Glowforge Settings (see image). Any ideas what I may be missing on the export?
Hi Derek…that’s a known issue with how the Glowforge design software interprets “islands” in a design. (The GF software always uses a Non-Zero winding rule. Affinity Designer can be set to Even-Odd. I think you can reverse the path direction to fix it…)
We’ve got a tutorial for the fix…@tim1724 worked it out…
I’m so sorry you hit a snag! Did the tutorial help you get your file uploaded the way you want it? If not, let us know and we’ll look into this further.
I’m glad to hear that the tutorial helped resolve the trouble you were having. Thanks @Jules!
I’m going to close this topic for now, but please do not hesitate to reach out to us in the future at support@plugable.com if you hit another snag. We’re here to help!
