How do I tell the machine the tray is out? I am doing a manual with tray out and engrave on something 2 in. The manual settings will not take 2 in defaults to .5.
The machine has no idea if the tray is in or out. It only knows if material it’s trying to focus on is within it’s 0 - 1/2" range. You need to bring the surface to be engraved to within that range and use “set focus”.
This might help:
If it doesn’t do a search on cutting without the crumb tray and there is a bunch of advice.
thanks
This comes in handy to ensure your work is in focus range with the tray out.
Thanks for the help @kanati and @deirdrebeth, that’s right. I’m going to close this thread - if the problem reoccurs, go ahead and post a new topic.
