What settings to engrave on tile on HD Pro
What settings do I use to engrave on tile on my HD pro
Check out #6, it’s all about settings — how to test, suggested settings for various materials, and general advice about what they do.
Also with tile it’s also about technique, there are lots of posts about how to color your engraves. Searching for “Tile engrave in:first #\glowforge-project-examples” will show you all threads about tile engraving projects posted in made on a Glowforge
https://community.glowforge.com/search?q=Tile%20engrave%20in%3Afirst%20%23glowforge-project-examples
Lots of those threads get into specifics about process which is the real gold.
The search function is very helpful for quick answers. Here is one: Framed Ceramic Tile
I use 250 for speed, 30 for power, convert to dots, and 340 lines per inch for Norton tile method.:blush:
If you have a moment it would be great if you could add that to the setting spreadsheet linked in #6 above. That way your experience could benefit people even if you don’t happen to be around or have the time to post about it.
