Maple/wenge 1/8". No veneer was harmed in the making of this box. Entire box is sanded to 600 grit and waxed/oiled with Feed-n-wax. Overall dimensions: 5 x 2-5/8 x 1-1/8" (127 x 67 x 25mm)
I wanted to make a curved box, but I don’t like the look for living hinges, and I don’t want to fool with using veneers to cover them up.
Enter kerf cutting. The general idea is that you remove material from the inside of your curve, and the wood can then be successfully bent. I’ll do this a bit differently this time and provide pictures with details inline, followed by technique and notes.
Maple/wenge 1/8"
I intentionally kept the edges of the lid (maple) brown, just as they came off the laser. I liked the contrast, and know from previous experiments that end grain looks different from side, so it would have had an inconsistent color on the edges, which I didn’t like.
I chose to cut the box in two pieces and join them with decorative butt joints. This allowed me to use less material… if you choose to do it as one long band, the resulting strips are quite long.
How long, you ask?
Here’s a strip, essentially one half of the box.
You can see it’s already 7" plus long, and this is a small box. It adds up quickly.
Maple/Wenge
Lid detail. The finger holes are .75"(19mm) diameter. They are two stacked rings of wenge that pass through the lid, which is maple on top, with a baltic birch insert (not pictured) to seat into the box.
What, you wanted to see the inside of the lid? Ok...
Here you go, the inside of the lid.
Maple/Wenge/Birch
I mean, it’s not super exciting, but I do have some mighty laserfingers.
Maple/Wenge
Detail of the exterior, it’s truly a round-cornered hardwood box.
Maple/Wenge
Here you can see details on the bottom. I elected to keep it “open” like this, and didn’t clad the bottom with a layer of maple. I like how it shows the kerfbend so clearly.
Maple/Wenge
Full look at the bottom and lid together.
Maple/Wenge/Rice paper
Rice paper? Are you crazy?
Well, yes. Rice paper is not an ideal box liner, it’s not tough enough. That’s why this is only temporary, and is only applied with scrapbooking tape. You might be able to get it to last by firmly gluing it down and sealing it somehow, but I like the idea of a replaceable liner when you want a different look. This was a leftover piece of wrapping paper that I just had laying around, thought it would look great.
A little overhead view, shows some detail of the corners and lid design.
Eagle-eyed viewers will see that the back of the box is where an owl lives. This led to an interesting #makerfail, each half of the box needed one end to be ready for the raven insert and the other end to be ready for the owl. Guess how I figured that out?
The hard way.
Don’t be me. These would work great if you had a double-owl box, but for my raven/owl box, not so much.
Detail of corner interior. As you can see from the open gaps, I could have bent the corner even tighter, but you start to have some problems at that point. I’ll get into that at the end of the post.
Maple/birch/clamps
Assembly required a little custom tooling to keep everything aligned properly. In boatmaking this is called a strongback, I’ll let a woodworker comment and tell me what it’s called here, but essentially I needed a way to clamp the woods in their final shape as glue set. It involved lots of clamps and some scraps of wood to keep everything flat and aligned on the butt joints. The clamping frame had the proper dimensions and radii on the corners to keep everything in place.
Baltic Birch
Here’s a detail pic of my clamping rig. The cutouts along the edges allowed me to get the clamps in place to hold the side butt joints in place as the glue set.
**Build notes and whatnot:**
I’m not sure anyone has gone so far as to actually make a curved hardwood piece like this yet. It’s been discussed in theory, and kerf bending is a well known technique, but I was unable to find anyone else who had gone this far with it. If anyone knows of a prior post, please let me know.
I started thinking this would be pretty easy. I made a “sawtooth” engrave to remove the kerf cuts, and got my settings dialed in, the end result would be a deep v-shaped engrave slot every 0.05" or so. This seemed like a good place to start.
Pro: Engraving the kerf relief worked.
Con: Settings proved really hard to get right. It seemed like it really wanted to just barely overburn and show through on the final outside surface. I had to do several test pieces to get it dialed in. Engraving is tricky.
To get the bends to be consistent and not crack, you have to soften the wood before you attempt to wrap it around your strongback. I used water. I wetted the surface of the maple over the entire kerfcut area and let it soak in. Once it was thoroughly waterlogged, bending went really well.
Pro: it was very successful
Con: it led to really messy laserfingers (water dissolved a bunch of the residue from the cuts/engraves) that wanted to put brown fingerprints on the wood. Don’t get it dirty, because you don’t have a lot of wood to sand away to clean it up later. It also added time to the process, because you have to let it dry thoroughly before moving onto final sanding/finishing. I left my masking on as long as possible to prevent as much mess as I could.
If you’re going to try it:
Give yourself ample time to work out your proper engrave depth, or perhaps use the defocusing technique that @paulw fooled with here. This was by far the trickiest part. Unfortunately (?) for me, I hadn’t seen Paulw’s post before I built this, so I never tried his defocusing method.
Test your bend radius before you commit to a fullsize piece. Bending a lot tighter is possible, but I found that when I tried to go too tight, the wood fibers started to split unpredictably. You just can’t go past a certain limit with maple, even when it’s softened. Think like a popsicle stick (from a popsicle you just finished). They break but sort of “softly”, kind of peeling apart before they go to pieces. This will no doubt vary by species or wood involved.
Determining the perfect inset size is difficult as well. You can get pretty close with math and material thicknesses, but there’s a lot of complexity happening with the wood here, so getting it perfect the first time is probably not going to happen. Cut your first attempt at a bottom out of cheap materials to test the size, and only once you get it just right go for your premium material. I decided to embed the bottom in mine, so I went with baltic birch ply, as no one will see the edges. (and the color is close enough to maple to be ok)
) (Edit: Except for the part where you generally have already done them so well that I can’t think of how to make them any better…!)
