This has been mentioned before. I think the conclusion was it is the side pieces that bow downwards due to the hinge torquing the back of the case.
Thinking about it some more I think the lid would have to open quite a lot to make that much difference in the centre. Short of the camera coming unstuck from the glass it is hard to imagine how it could be that far off.
In the corners it only needs a small angular change, or a small difference in height to make it off, but in the centre the bed is much closer.
Yah, I guess I missed the part where getting the autofocus from the red laser to feed into the kid camera focus. But then I also would think itās a no brainer to use the head camera for alignment.
My Pro arrived an hour ago. It has the same exact bulge. The founderās ruler printed perfectly. I understand yours worked fine and then went wonky, Iām just saying I donāt think itās the bulge.
I didnt think much of the ābowingā because it didnt seem to cause me much issue but I just grabbed my trusty straight edge and youāre right, the glass lid is dead flat and the side panels bow slightly. Although I suspect the bowing is simply because itās a large flat expanse of plastic which is really tough to keep actually flat. The bowing does not change dynamically while the lid is opened and closed.
Well, I beā¦ they sure are. I honestly hadnāt looked that closely but I just tried scratching it with a blade (the less visible edge, not the face muwahaha) and yep, itās glass too.
Iām still not seeing any flex in the case because of the hinges though.
Yes, the two pieces on either side of the lid appear to be glass. As best as I can tell for aesthetic reasons. A metal bevel runs around the top, but the rest of the case is plastic with metal bits here and there.
Just because I can identify with a ālid problemāā¦I had to send my PRU back because the glass lid actually was separating from the hinge in the left back cornerā¦which caused the lid itself to not close flush with the left side of the opening. I know, a different issue than this, but just gave me pause.
My PRU lid is slightly proud of the center of the side glass top pieces. The lid seems dead flat on mine. Might be some other issue for focus and registration. Hope you get it resolved.
Iāve had very good success with placement of images over scrap pieces of material and using even very small pieces so anything that out of placement is a bit strange.
Do you have some type of test image that you can put over cardboard and give a good benchmark of whatās going on now?
This topic has lots of good discussion of camera alignment and a few good images of what to expect from a few months back.
Unfortunately, my shift is deemed within the expected range now, so thereās no fix from Glowforge until the software works better. The shift from almost perfect to this far off happened from one print to another and doesnāt show any signs of getting better which concerns me about making jigs. Iām willing to wait out the permanent fix with software, but if I build a jig today, is it going to be wrong tomorrow? I wish I knew why it happened. Predictable error is much easier to handle.
Very strange that it used to be OK but now needs a software update to get back to where it was. Was it a software update the broke it or did something physically change I wonder.
The stated range is within 1/4" but your seems slightly outside that on the picture of the ruler. And the fact that it is off in the centre is very different from it being off in the corners and requiring a better lens de-warp algorithm. Either the camera or the head must be pointing not straight down or the software is adding an incorrect offset.
It is like it has lost its factory calibration somehow. Perhaps the improved software will include a way for the user to re-calibrate it. I donāt see how a problem like this can be fixed otherwise.
Can answer why this is now. I watched more carefully the red laser depth check is not done until you send the print. So the depth is not being read whenever there is material in the bed to populate the field. Probably not as quick a fix now that work flow has to be rerouted.
