I went to a reclaimed hardware place and just picked up a bunch of assorted materials to test on.
I was thinking these marble tiles might make nice nameplates.
Here’s my first experiment.
Settings: full Power, full speed, 225 lines, 3 passes. Worked even with 1 pass, but did not go too deep, so I just kept going.
Would love to make it look beveled but I’d have to spend a little extra time making a gradient around the lines of the letters; so probably won’t get to that.
Looks great!
I’ve done a bevel on hard wood. Turned out well and was easy. Just made a rectangle on the edge, pulled in the top and bottom inside corners to a 45 degree angle, added the gradient, cooy and paste the put them into place. Used variable power.
You want to do the letters? Are you familiar at all with Photoshop? Is so, just use the blending options on your text. Play till you get the look you want.
Made coasters for my brother in law. He a Virginia Tech fan. I just put an inside shadow on it and adjusted. Bevels would be better to use engraving the text in.
