Random lines showing up on work
I have used the same file three times. First time the line doesn’t show up and it is no where to be found in the actual file. I then proceeded to laser a nice neon acrylic and not that is ruined. Is there an issue with the cloud software slicing the file up?
That can happen occasionally if you have open vector paths in the file. The software tries to close them.
The easiest way around it is to rasterize the image to be engraved. (Use a high dpi value (>300) and the results will be indistinguishable from a vector engrave.)
There’s lots of posts about it and these will get you started.
Random lines FIGURED OUT! (but not a fix)
Apr '18 - I’ve had random lines appear in two engraves since last night. I’ve seen at least five other other people report the same issue today. I engraved an SVG once and got…
Random line across design
Dec '18 - Every once in a while I get a random line across my artwork like the laser forgot to shut off. 20181203_154456.jpg 20181203_154456 20181203_154456.jpg 4032×2268 2.57 MB 20181203_154529.j…
Random Line Engraved
Nov '18 - So, this isn’t the first time I’ve gotten a random line in my designs. Just not to happy to see it after waiting an hour for this thing to engrave. The file itself does not have a line. When this happ…
Random Lines in Acrylic Engrave
Apr '18 - Yesterday I cut the same file twice and both have random lines in them. The first had a couple of smaller vertical lines in it. I cut the second one due to the small lines in the first and the second was fa…
Random line while engraving
Mar '18 - …1154 271 KB 6EEDCEC7-7949-47F2-A4D6-FB4B85EDF185.jpeg image 6EEDCEC7-7949-47F2-A4D6-FB4B85EDF185.jpeg 866×1154 374 KB The on the upper pic there is a random line connecting two images (to left of big P) that is not there on the bottom pic and also on another engrave. Not sure where it came from since it e…
1h - I have used the same file three times. First time the line doesn’t show up and it is no where to be found in the actual file. I then proceeded to laser a nice neon acrylic and not that is ruined. Is there an issue with the cloud software slicing the file up?
Random Lines being added to engrave
Feb '18 - I have tried engraving this design three times and, each time, one or more horizontal lines get engraved that are not in the design. Always in a different place. Any ideas what might be causing this? 28555569_10213660537660742_1531563825_o.jpg 28555569_10213660537660742_1531563825_o 28555569_1021…
Random Cut Lines Shifting
Feb '18 - …g Shift1-B Shift1-B.jpeg 866×1154 309 KB Shift1-C.jpeg Shift1-C Shift1-C.jpeg 866×1154 469 KB The second occurrence shifted the large rectangle and a random circle elsewhere on the file. (See images Shift2-A-B-C) Shift2-B.jpeg Shift2-B Shift2-B.jpeg 1154×866 291 KB Shift2-A.jpeg Shift2-A Shift2-A.jpeg 866…
Thank you for the suggestions @Jules and @kittski!
@a.vidaurrqzaga, could you try the above suggestions and let us know if they help?
The best part is that they ALL say “random lines.” :rofl:
I know,! I had noticed that last time I searched for it. Kinda why I posted it this way becasue it made me LOL a bit.
Havent had the chance to revisit the project but it does take about 40min to laser so I am not sure I will have a chance to sit and wait for it to fail with orders to work on. I will update this thread when I get the chance hopefully this upcoming weekend. thank you everyone for the feed back.
