Make some . You will find these useful. As soon as I figure out where to share Files. I’ll
Be happy to offer it “open source” . Is there a files section for that purpose ?
here is a link to the post where i put the file yesterday (in case it didn’t make sense.) Honeycomb bed holdown pins
As @kittski said, there is the “free laser design” category, you can zip your file and then drag it right into your post. You can do the same with an SVG but by zipping there is a less chance of corrupting it. And thanks.
Brilliant idea, using the crumb tray grate to hold the pins in place! I’ll be printing a bunch of them once they’re available! @dan you should put 'em in the catalog! Perfect “second print” after the ruler!
Now, how best to print as many as you can in a piece of PG…I’ve tried using this design here at http://svgnest.com and cannot seem to get it to work. Any ideas? TIA
Just encountered a pretty warped piece of MDF and I remembered this post. Zapped out 6 of these little cleats and they worked great. I made mine from ‘eighth inch’ MDF (closer to .13" in reality) and they are a very tight fit - I might make some that are a hair smaller so they don’t damage the honeycomb.
I just tried that web app also . Seems to make a mess of things. Seemed like that app would have lots of poterntial. SVG are funny animals and often behave strangely depending on the encoding. I would be glad to lay them out for you. I tend to use Corel draw for laser design and occasionally have compatibility problems. I’m
Not sure if this will help but I use it all the time to fix SVG files for web app development (my day job)
Check it out. I haven’t run the bed pins through it yet… https://jakearchibald.github.io/svgomg/
