Lens Fail: Burnt O-Ring; Not Cutting Through Material
Gacked Lens Housing:
I set up my Glowforge according to the directions in the owner’s manual.
I successfully cut two Gift of Good Measure (Glowforge - the 3D laser printer) files.
Then I tried to cut a custom file based on the Print a Gift Tag (https://glowforge.com/support/topic/first-three-prints/3rd-print-gift-tag). Unsuccessful.
So I tried cleaning the lens as suggested here: HELP! Not cutting all the way through gifts!
I followed the directions for cleaning and wiping: https://glowforge.com/support/topic/cleaning-service-and-moving/cleaning#things-that-need-wiping
I found the lens was gacked.
And even after I wiped with the lens cleaner, I still saw an occlusion in the lens.
I re-ran a file
It did not cut through the proofgrade medium density board
I checked lens housing and found something right snorked:
Unplugged Glowforge and stowed away.
References:
That was a beautiful description of the problem. (Support’s gonna need to step in, obviously. Just wanted to express admiration for your technique.) :slightly_smiling_face:
Thanks.
I hope it is useful for others trying to troubleshoot.
