Return to the common questions index
First the bad news:
In general no Glowforge model is powerful enough to remove metal material, so using the laser to cut or engrave into the metal really isn’t possible in almost all cases.
There have been some cases where it appears that the Glowforge has actually etched into titanium, but I’ve never seen it duplicated so I can’t confirm it. See below for the post about discoloration of titanium for more details.
Now, the good news:
There are ways to interact with metal. I’ll go through the basic categories.
Surface marking
You can use a marking agent to coat the metal, then laser engrave that coating, which permanently bonds color to the surface. The most common ways to do that are with marking products (like Cermark or Laserbond) or with some homebrew marking agents (like vinegar or dry moly lube). Even things like mustard have had some success with steel. For more information, try the following searches:
Search results for 'cermark' - Glowforge Owners Forum
Search results for 'laserbond' - Glowforge Owners Forum
Search results for 'mustard' - Glowforge Owners Forum
https://community.glowforge.com/search?q=marking%20metal -
Color removal
The flipside to using a pigment like Cermark is to first color your metal and then use the laser to remove that color. The two main types you see here are painted metals and anodized metals. For more information:
https://community.glowforge.com/search?q=painted%20metal
https://community.glowforge.com/search?q=anodized -
Discoloring
Uncoated titanium can be discolored by heat in a variety of hues. For more information:
WHAAAT!? You can mark uncoated titanium!? - #57 by Hirudin
Best metal for outdoors - #47 by Xabbess -
Chemical etching
In general with this method you cover your metal with a barrier material called a “resist”, then use the laser to engrave that protective layer away. Then you submerge your metal piece in a chemical bath that etches the now-exposed parts of the metal. For more information:
https://community.glowforge.com/search?q=resist%20etching -
Physical deformation:
The embossing work by @vegandarwin has been really impressive.
So, with these techniques you can do a lot of cool projects by very creative people, here are a few:
Resist etching:
– This one is particularly interesting because it is best done on an Aura.
Paint removal:
Dry Moly lube:
Cermark:
Laserbond:
Embossing:
