Engrave and Cut 1/4" Mahogany tips?
I want to create something out of 1/4" solid mahogany. From a quick search on here, it seems that mahogany seems to flare up and catch fire. Any tips on settings and passes? Or should I just pick a different wood?
The support team can’t give recommendations on non-Proofgrade material settings, so I’ll move this to the Beyond the Manual section for you so any customers who might know the settings can give them to you. (I’ve never tried it, but I’ll bet someone has.) :slightly_smiling_face:
It’s been a while since I tried, but the 1/4" mahogany that I had just didn’t want to be cut…
You’re going to need a lot of passes (over 20, most likely) at high speed and possibly reduced power to avoid a charred mess. I’m going through the same thing right now with 1/4" zebrawood. My first try, with 15 passes, resembled charcoal by the time I got all the way through. My second attempt, with 21 passes, is slightly better, but I’m trying again with 30 passes (and lower power) tomorrow.
Snapmark is proving useful. It allows me to take the piece out, examine it to see how far it’s cut through, and then put it back in the machine for the next set of passes. It does take a while to re-align it to the Snapmarks each time, but it’s worth it.
I have just today run several tests on both Mahogany and Zebrawood, On the piece from Ace Hardware, one pass at full power 160 zooms it cut in one pass, The other two pieces did not cut through but burned. Given that Mahogany will burn when heated, and a little char will lead to more, having a great many passes IMHO is a losing game. I am not sure you can keep the smoke from burning as even at 300 zooms it will flare. what you can do is reduce the effect of that flare at burning where you are not cutting, as once a coal gets started it tends to continue,
One way to do that is a strong masking that will keep the flare away. If you are engraving however that does not work. In that case, I did multiple engraves (like 4) but soaking the wood with water before each pass. As long as the wood is wet the flare will not burn it, but the cutting point is so high it has only the slightest effect on the cut.
I have long thought that if it came down to it dry ice in the crumb tray would lower the oxygen content and prevent burning, but I have not been desperate enough to try that yet. When I use up the mahogany I have I don’t think I will be buying more. Zebawood is similar but not quite as bad.
Also in my tests was 1/2" Paduk that did not burn even at 100 full and almost cut through with 2 passes @ 150 full. Not many woods will cut at all without major char at 1/2"
My mind keeps playing crazy editor Like " Engrave and Cut 1/4" Mahog. Any tips?"
My results on 1/4" zebra wood, which I believe is a somewhat similar challenge to mahogany (although perhaps not quite as bad):
Note: this is on a Pro, so Full is more powerful than Full on a basic.
  1. 6 passes at 250/full followed by 9 passes at 500/full, lowering the focal point as I went: This looked horribly charred, but it actually cleaned up quite nicely. The edge is noticeably slanted (with more material removed at the top than at the base) but not too bad.
  2. 21 passes at 350/full, lowering the focal point as I went: similar very results to attempt 1. Slightly less charred but not worth the extra time.
Those were the two that I referred to as charcoal yesterday but they actually ended up cleaning up well. And I hadn’t yet seen how much worse they could be. :slight_smile:
Note: remaining tests had a sacrificial piece of chipboard under the wood, to minimize the flashback which appeared to be responsible for some of the char.
  1. 3 passes at 100/full (all focused at the surface): this not only cut all the way through the zebrawood but also cut almost entirely through the chipboard! The result was a lump of charcoal. Unusable. 1 or 2 passes at 100/full might be worth trying, but I decided not to pursue that route.
  2. 4 passes at 200/full, 1 pass at 150/full, lowering the focus as I went. Failed to cut all the way through and I abandoned it because it was another lump of charcoal.
  3. 5 passes at 150/full, 1 pass at 125/100, lowering the focus as I went. I finally got it cut but it was charcoal. I decided to abandon the slow high-powered cuts.
At this point I decided to work on a two-sided cut using Snapmark alignment.
  1. 3 passes at 250/100, flip, 3 passes at 250/100, flip, 3 passes at 250/100, flip, 3 passes at 250/100. Success! This is similar to attempts 1 and 2, but faster and slightly less charring. Also the profile of the cut is nicer!
That last attempt is a real winner. Not too many passes and manageable charring. Plus the profile is more like (_____) whereas the single-sided cutting produced a cross section like this: /_____\ (The difference is subtle, though, so probably not important in most cases.)
I’ll be trying it out for real on a project next week (and perhapsI’ll try to write up a tutorial for 2-sided cutting using Snapmark) but I’m feeling a lot more confident about my success now.
Here are my test pieces for tests 1, 2, and 6.
It’s only had minimal cleanup and could certainly still use some more work. Here you can see how much darker it is than the un-lasered wood:
Anyway, this isn’t mahogany so it might not be helpful. But I will say that I’d probably try more lower-power passes rather than a few really strong ones.
This is the test I run on every new wood species and often on several to test what I want to actually use. but this first test runs the engraves at twice the number noted and then comes back and makes the cuts at the numbers noted and then cuts off the piece at two passes at 125 all full power.
evans%20tests
Watching closely while it is done allows me to put a wet cloth on after it cuts in the case where it starts to make charcoal,this is the Zebrawood piece after sanding it as the cut is deeper and burns more where it hits previously cut places (in any case, not just this wood)…
I ran another test on an unknown wood I suspected was Zebrawood but I re-arranged the cut sequence to do the engrave first and then the cut for each different setting and doing the final cut before the last two. in this way, there was less time for the charcoals to burn,
It was zebra wood and it cut through with two passes at 125 for a 0.275" piece
Of perhaps more interest by cutting across the engraves first, it hardened the wood on each side and the engrave only cut 1/3 of the total distance for fresh wood!
This could be why multiple passes are not as effective at cutting as the first pass.
Updated Material Test Template
Link color to cut setting
File too large to cut on the forge as is, can it be taken apart to cut smaller pieces?
Cannot cut what it used to
Want to create patriotic things
Power/Speed Settings
Cut settings for 3/16 Cell Cast Acriglas sheet
Needed a shelf / spice rack
Newbie here and completely overwhelmed
Cutting on Non-Certified Material
Raster ablation on Stahls Cad-Cut Heat transfer vinyl
Help with Cut, Score, Engrave settings for .05" Acrylic
Trying to find clean cutting parameters for Johnson Plastics Plus wood
Cutting 1/4” wood?
Dozens of design files missing from library
Not cutting through on the proofgrade
Purchasing material
What am i doing wrong? not cutting though
1/4" birch cutting issues
Glowforge not cutting wood
Manual setting for Birch
I keep running into cutting problems
Calibration Samples
Thickness of wood
Proofgrade shipping to Canada still a problem
Teak settings
Anyone have any luck with Leopardwood?
Glowforge Plus Cut Thickness
Using nonproofgrade
Revolution ply and questions about fire
First cut problem need advice please
Curious on how to tweak settings for cuts not going fully through
Trying to cut 1/4" Baltic Birch Ply, having burning issues...any recommended settings?
What speed do I cut 1/16 exotic wood on?
Buying & using "Proofgrade Materials"
Another cut test
Glowforge Notebook
Settings help with cutting 1/4 African Mahogany Hardwood
Test cut files using Affinity Designer is it possible?
Celtic Knot Trivet
Best Practices
Bad Walnut?
File for engraving settings
Keeping detail in a dark engraving
Questions, so many questions
Backend Changes for File Rendering?
Settings for engraving 1/4" Baltic Plywood
Laser engrave everything
Pro Crumb Tray
Sorting Projects
Consistency issue daily
Uploaded Cut file won't cut
Stopped cutting. Engraves but not cutting
Uneven cutting
Best Practices
Good news ! I just ran the test on Half inch Walnut and 100 almost got through and three passes at 125 cut it with a minimum of charcoal. So that means the Paduk and Walnut are ideal woods and from my tests I think Maple might be there too!
Here is 0.40 walnut ultimate test.
