Last Week’s Highlights:
We’re Off to See the Wizard
Drop the Mic
That’s incredible!
I’ve had that challenge too - breaking up lines between cutting & engraving in a single piece makes my brain hurt a little.
Do Not Try This At Home
VIDEO
All directions lead to beer.
https://community.glowforge.com/t/number-of-posts-read/6683/24?u=jules
unfollow, no favorite, please make it stop
Does the Glowforge have onboard memory? Can’t it just recut a file immediately without re-processing the file?
It has a great deal of onboard memory, but if you simply replayed what was in it, you might get the wrong focus, wrong location, wrong material settings, etc, depending on how similar the new piece of material was to the old one.
Boo-Boo Kitties
After seeing some of the other mobile device stands folks made, I knew that one of the first things I wanted to try was a cat-themed one for my wife…
[image]
Yes, I left the masking on one kitty as an accent. I thought it made the design pop a bit.
I’m pretty happy with it, but made a few boo-boos. Luckily, I was able to use superpowers to fix one of them.
Boo-boo #1: Forgot to take into account material thickness when I resized the SVG in the GFUI. When the print …
/uploads/db6859/optimized/3X/5/7/57c2df72d2bf7efcc1decdcccb4474121be0dba1_1_666x500.JPG
Oven Rack Relief
Testing the rapid-prototyping waters, I just used a sharpie on a piece of Proofgrade Maple to make a oven rack pull (riffing off of @Jules example). 4m15s to engrave and cut.
[image]
Did I mention that I my ?
/uploads/db6859/optimized/3X/4/3/43629871510263f66cc5ec07689c2d50b9f26ca5_1_666x500.JPG
No Foolin’ (Another Pre-Release! ) Congrats @Drea !
[image]
Rita’s email came on Tuesday. I had to re-read it a few times before it actually sunk in that it wasn’t a joke, and that I really was being offered this wonderful opportunity. As so many others have said, my response was an incoherent:
YES! yesyseyesyesyesyesyesOMG yes, yes, yes!
(or something to that effect)
My Squeeforge was scheduled to arrive on Friday, which gave me a couple of days to quickly get my office and my act together … or so I thought. Instead it arrived on Thursday (p…
/uploads/db6859/optimized/3X/a/c/ac02811d53cfaaa752e6a81f162859177a9d70c9_1_500x500.jpg
Take the Red Pill
Arrrgggghhhh! Which Way?
My wife really liked the sign I made as a gift for a friend so she asked me to make a double sided pub style sign for her team at work. I am really happy with the way it came out. Once again I took advantage of the masking to make my paint work look a lot cleaner than it would be otherwise. For me the hardest part of this was making the vines interact with the main body they way they do. Making a line cut one place and score the other turned out to be a lot harder than I expected and took severa…
/uploads/db6859/optimized/3X/e/2/e21cfefc43ce27cf3175b43cd014677c051b9649_1_666x500.jpg
Birth of the UBU Boxes
So, I wasn’t going to post this but I made the mistake of mentioning it in another thread and now I have to.
Anyway, this it a good time to mention what I am doing this week. That extended Y-axis base for my handibot arrived and it needs beta testing. Also ever since the Glowforge arrived, I’ve been playing 3d Tetris in the office here so this is what I have done. I have taken a week off from the salt mine to work on “personal infrastructure”. Each project may or may not utilize one of the smar…
/uploads/db6859/optimized/3X/c/4/c41ef2de8f6c5a61980213fa6b0d71d0a577b5cc_1_281x500.jpg
Somethin’ Fishy About This Highlights Reel
I needed a quick display item for the week and since we had a request waiting I decided to go ahead and just knock one out real quick - it took about half an hour.
[image]
(Note: I deliberately did not adjust the settings and didn’t mask because I wanted to also test for a couple of other things. The result comes out much darker than what you will likely see when you cut it, especially if you cut it out of Proofgrade.)
One thing that did surprise me…I would have expected lines cut that clos…
ragg MOPp
A couple weeks ago I tried cutting a standard blank of Mother of Pearl for use as a musical instrument inlay. It was a complete failure.
Thought maybe a thinner material could work. So I tried a very thin 0.008" Mother of Pearl veneer. This is thin (and expensive) stuff, only about twice a thick as standard copy paper. You can see the difference between trying to cut the thick shell (right) vs. the thin MOP veneer on the left.
[image]
The latest cut is relatively precise with only s…
/uploads/db6859/optimized/3X/0/9/0955c57a81571dfd0590d40216218449a6e9a7c7_1_690x458.JPG
VIDEO
Just a Quickie Tablet Holder
So I’ve been needing a tablet holder for when my reading at the kitchen table is electronic the tablet doesn’t lie flat.
I found this over at Ponoko, it gives two different angles without any mechanical adjustment.
The hard part was that if comes as an eps file. Turns out that Vcarve Pro will import eps and export SVG.
The file said it was for 1/4" so I grabbed some Homedepot 1/4" that mikes out to .200". Well, it was way too loose so I went back into Vcarve and tweaked things and cut again.…
/uploads/db6859/optimized/3X/c/4/c42a7cecce0ddc69cd8c871d2e8dbf15c6e663ba_1_690x388.jpg
Alignment Suggestion
TLDR; This is not a feature. This is a suggestion on using a physical target to assist the Glowforge UI in auto centering / aligning designs on small one off materials. This is a THEORETICAL idea on how to do it. NOT AN ACTUAL FUNCTION.
This is a continuation to this thread. But this thread is mostly for single, one off ops.
Has the same idea- But used to recover failed ops.
As it sits now you have to manually align things in the UI. If you are doing a large batch- @takitus link has the b…
/uploads/db6859/optimized/3X/6/4/64d591f53516eba073b8e6bca770bac00c567806_1_690x417.jpg
How 2 Use the Inkscape Elliptical Box Generator
Here Kitschy-Kitschy…
Starting to get into a few 3D designs now, which take me a little longer to assemble.
(I wind up with glue in places you would not believe!)
This was one of my earlier designs for a kitschy little brush stand. (Probably a bit of design overkill just to get it off the counter. Chuckle!)
[image]
This is the one that @Hirudin cut and assembled to help test parameterization last year…
(Link below if anyone wants to watch.)
Hirudin video of cut
I did wind up taking his suggestion and…
/uploads/db6859/optimized/3X/9/0/9040abd7c6a007ad6cc6ec18cc51a43e5a99213b_1_666x500.jpg
Harley
Supplies: Proofgrade 1/8" Walnut - Op Time: 1hr 8mins
Engraving.
[image]
Exhaust from outside. Booster disabled.
[image]
[image]
[image]
[image]
/uploads/db6859/optimized/3X/c/7/c74c2ad59f0669dd473c5a891ec18ae25e791b76_1_375x500.jpg
And MBBs
You are seeing and will see a lot of boxes and trays from me because that is what I am working on right now, personal infrastructure.
I got the plans for this from Laser cut wood - CARTONUS
Somehow, the kerf is perfect for the box joints on the drawers but a bit tight for the main box. If I make another one I will adjust for that.
I have not installed the pulls for the bottom three drawers yet but I could not wait to share.
Be aware if you want to build on for yourself that it burns through …
/uploads/db6859/optimized/3X/3/f/3f9751a29b34ce6c4b38f974e4b4e8723e085596_1_690x388.jpg
Tool Carousel - (Catalog Print)
Another catalog print for you!
[image]
I added a little embellishment to it as it’s for my desk at work. Enjoy.
/uploads/db6859/optimized/3X/1/8/18d7cfba5a287fe75f99c528b5935c3888e5f658_1_666x500.JPG
Air Fresheners a la Glowforge
New Pre-Releaser (Congrats @nunzioc !)
I think this is the most priceless pic of all…
[image]
BIG Box…came later…I was on pins and needles, lol
[image]
Be sure to check these before the delivery person leaves!
[image]
[image]
Everything except the forge…the anticipation was killing me…
[image]
Bed packed so well!
[image]
It’s so beautiful…can’t believe it’s real…
[image]
Soooo much proofgrade stuff, and packed so well, and all of it is beautiful!
[image]
[image]
[image]
[image]
The first thing I made
/uploads/db6859/optimized/3X/8/d/8d4bcd6acf60aa63d6b3b956a851ec3dfa76b880_1_666x500.jpg
BooBeBooBop
Engineering to my wife’s preferences is proving more time consuming than I thought. There is always the “what if you did this” comment that comes after the project is almost complete. So far only three designs completed. The Banjo guy has a swinging arm and head; Mandolin Girl has a swinging arm, leg and moving eye on the moon; the campers have two kids bouncing up and down in different windows, a dog moving left and right in the door, and the flag swinging back and forth. Let’s see w…
/uploads/db6859/optimized/3X/3/8/386144cdc379bb438b460e7df611bb697a4cc286_1_690x459.jpg
Another new Pre-Releaser! (Congrats @dwardio !)
Trogdor is in the house!
/uploads/db6859/optimized/3X/c/6/c6bce4063a02ca8a158b902cdf7bb1d480a8d48f_1_666x500.JPG
Scroll Bowls
/uploads/db6859/optimized/3X/d/4/d4ee853694cb08f575c83c68b426afd61d448ad9_1_666x500.jpg
/uploads/db6859/optimized/3X/f/6/f62beb6176b4952a7ad5f94406c2e7e42cc8dc62_1_666x500.jpg
And Another! (Congrats @cynd11 !)
/uploads/db6859/optimized/3X/9/e/9ef9a9af1ee6a66572c4bd7e1a46af74d039ca61_1_690x490.jpg
If you haven’t seen my previous announcement , I was offered a Pre-Release Basic Glowforge! After mulling over my unworthiness for about 20 nanoseconds I quickly accepted. Email arrived on Monday night but I didn’t see it until Tuesday morning. Imaging my excitement when they said I could have the machine next day!
It arrived Wednesday March 29 by FedEx Priority overnight which means delivery by 10:30am. I don’t know if this will be also true for production units but thought folks might like…
/uploads/db6859/optimized/3X/5/7/57223f86282d59d84e6b92773ff29d5354b80566_1_410x500.jpg
Leather Earrings
Okay, sorry for the barrage of projects all at once but these are what I’ve created over the last 3 days and I’ll be taking a break for a couple days to give you a rest.
Here’s another project that has been rattling around in my head for a long time. I created it in Illustrator with all lines set to black (cut) except the score which was set to red. The stitching holes were a challenge. My first attempt (on the left) did not account for kerf and as a result the holes were too big, …
/uploads/db6859/optimized/3X/4/b/4b8deec17c7a8b14e4e7603ac72dd09cbd9ffc76_1_517x500.jpg
Proofgrade Battery Dispenser Box
This one is currently a problem child that I get asked about occasionally, so I’m reworking it for laser use. (Not quite done yet - it needs some serious size tweaking, this one holds too many batteries, but I figured I could show what it will look like done in the three Proofgrade plywood materials currently on offer. These are 1/8" ply, but I’ve got the current file set up to parametrically adjust for any thickness wood up to 6 mm. Frankly, it’s scary.)
[image]
The file uses a shal…
/uploads/db6859/optimized/3X/e/a/ea3388034cfb8e221924c828aa33327e81d3ac36_1_666x500.jpg
Journal Cover
Here’s a project I’ve been wanting to do for a long time, but didn’t have it ready so I spent quite a bit of design time on it. I happen to own a Rubicoil spiral binding system (basically, the heavy duty punch that punches the closely spaced holes for a spiral coil). I wanted to make wooden covers for a blank journal.
You would not believe how many iterations I went through in Illustrator before I got the holes of the right size and spaced correctly. I used the blend tool in Illustrator betw…
/uploads/db6859/optimized/3X/b/6/b605f75c5db0bf198642043b7997bc5ff1115c85_1_434x500.jpg
I’ll Be Back
Pop-ups
And Popcorn
Interior grade with a coating of Spar Varnish might work. (Heck, if it’s good enough for boats…)
What the Dog Bought
So what’s the craziest thing you can say happened to you today? I’ll start…
My dog bought a $45 African fertility idol at auction today without my knowledge or permission. The dirty b*stard…Now I gotta go drive across town to pay for it… True story
Whoof?
/uploads/db6859/optimized/3X/2/7/278c9f621f62c95f05c70da1348e47b7133879cb_1_690x460.JPG
Frozen Treats
My favorite part is watching it try to render the subtitles as ASCII art. It’s like code… trying to render letters with the wrong letters.
The Colonopsicle!
So had the inspiration from the artery project and the colon project, to try the spinning mandrel (thanks @marmak3261 for the actual name) for the colon. so I present to you:
The colonopsicle!
[image]
[image]
[image]
[edited as the video wasn’t working as an embed]
/uploads/db6859/optimized/3X/e/6/e617ee405da7c1eb2e0d8961a2231b7de8ea357f_1_375x500.jpg
This is how I get my daily chuckle–reading this forum. What a gas!
Ouch. And here’s a pro-tip from 3D printing: if you let the stepper motors grind against the hard stops for long enough they can produce electrical spikes that will let the magic smoke out of other parts of the controller.
Blacksmithery…Blacksmithery I say…
@ihermit2 suggested I should throw a few pictures of my anvil build on this thread!
This is what I started with. My brother and I lugged pieces of a cut up railway about a kilometer. Biggest one was around 80 pounds.
[image]
I started the project by cleaning the whole thing and flattening the top a bit!
[image]
I marked out the horn and then started cutting and grinding
[image]
[image]
[image]
And after a paint job here is the final thing!
[image]
Months later I built a stand for …
/uploads/db6859/optimized/3X/d/4/d4461eac97ae2c21292973474cbc49f917641064_1_375x500.jpg
Thanks for posting that. There is something so satisfying about working red hot steel. - Rich
Shop Stools (Are we allowed to use other tools?)
I am literally the handibot’s biggest fan. If you go googling it you will start seeing me and mine right after company stuff.
The handibots design philosophy is a bit different than most cnc in that you take it to the work instead of having a fixed base. The biggest complaint has always been it extremely small cut area of 6X8".
Brian who is in charge of the handibot project sent me a prototype extended Y-axis to try out/beta test.
My thoughts so far are “wow, now more than ever the handibot i…
It’s a Blast
https://community.glowforge.com/t/show-and-tell/1731/1668?u=jules
/uploads/db6859/optimized/3X/5/c/5cffd6aa2b7c30305421bca5d647479541a3b28c_1_605x500.jpg
Luthiers Anonymous
https://community.glowforge.com/t/show-and-tell/1731/1656?u=jules
/uploads/db6859/optimized/3X/a/7/a744552669779a04666698f80b02d9c7ad5aff5e_1_690x460.jpg
https://community.glowforge.com/t/show-and-tell/1731/1672?u=jules
/uploads/db6859/optimized/3X/f/5/f59389a935785e7d8d4bacee893f65f687f4d3e8_1_375x500.JPG
Tutorial: Concepts for Creating a 3D Depth Map for Engraving using 2D Design Software
https://community.glowforge.com/t/tutorial-3d-engraving-depth-map-concept-using-2d-design-software/6724?u=jules
/uploads/db6859/optimized/3X/4/2/42fbb823762dac7c0bb019ccef05439148848957_1_345x240.jpg
Make it so Number One
https://community.glowforge.com/t/hanging-around/6620/47?u=jules
/uploads/db6859/optimized/3X/0/5/05e1936506a1f831216aafe8204669163a6463e5_1_666x500.jpg
Local forum member news:
@Jules has fallen down a well and may not have internet for a while. Lassie has been dispatched to find help, till then volunteers sought to help weekly highlights to appear. Film at 11.
Dragon Drop (Posting SVG files to the Forum)
/uploads/db6859/optimized/3X/b/f/bf71e07b78c9e3a0b427d0f18283e0ffcbbe2038_1_384x500.svg
The Strawberry Saver - Shared File
https://community.glowforge.com/t/the-strawberry-saver/6742?u=jules
Pre-Release Arrival
https://community.glowforge.com/t/just-got-a-pre-release-yesterday-some-pics-items-made/6765
Freebies
https://community.glowforge.com/t/free-designs-fonts-site/6775?u=jules
/uploads/db6859/optimized/3X/f/d/fd64dea1785933fbbd64e15d4c9c08c91489c3ec_1_690x460.jpg
DIY Coin Sorter
https://community.glowforge.com/t/glowforge-coin-sorter/6778?u=jules
https://www.youtube.com/watch?v=7ILHtAPY29I
Vector Elementals
https://community.glowforge.com/t/periodic-table-of-the-elements-in-ai/6783?u=jules
http://www.briandalessandro.com/blog/the-periodic-table-of-the-elements-in-adobe-illustrator-format/
Subtle Layering Technique with Engraves
https://community.glowforge.com/t/subtle-layering/6790?u=jules
/uploads/db6859/optimized/3X/0/1/01fac1b417808331b108efcabb47eafc67a0dc73_1_666x500.jpg
